Author: Subject: Pinto oil pressure and water temperature sender threads
andyharding
posted on 9/3/05 at 07:39 PM Reply With Quote
I'm planning to order a set of gauges from greengauges.com.
The water temperature sendor is available with a NPT or UNF thread. What type of thread is in the Pinto head?
The oil pressure sender is only available with a NPT thread. Is this the same as the oil pressure switch on the Pinto block?
Thanks in advance.
Are you a Mac user or a retard?
alan wheeldon
posted on 9/3/05 at 08:25 PM Reply With Quote
im pertty shure its a 5/8" UNF one u need for the head
britishtrident
posted on 9/3/05 at 08:32 PM Reply With Quote
Seem to recall some ntp thread sizes are the same tpi, dia and form as a unf thread but that most ntp threads on cars are ntpt --- ntp tapered.
britishtrident
posted on 9/3/05 at 08:46 PM Reply With Quote
re last post my memory is playing tricks for pipe thread ID see this url http://www.eldonjames.com/frames/thread.html
James
posted on 10/3/05 at 08:07 AM Reply With Quote
Sorry for hi-jack but just out of interest- why'd Ford use an unusual (ie. non-metric) thread?
Only reason I can think of would be that the NPT is fine enough to stop leaks that would occur with metric- but experience tells me that metric is ok for that!
Thanks,
James
britishtrident
posted on 10/3/05 at 08:34 AM Reply With Quote
Pipe threads have always been an area where imperial/us threads are the norm.
David Jenkins
posted on 10/3/05 at 08:37 AM Reply With Quote
NPT requires some form of sealant to be 100% water-tight. NPTF is self-sealing (the thread is designed to distort when tightened, filling the gaps).
I bet Fords used the cheaper NPT though!
Thanks,
James
NS Dev
posted on 10/3/05 at 11:27 AM Reply With Quote
Thanks,
James
these threads are not unusual, very standard for fluid connection purposes.
andyharding
posted on 10/3/05 at 11:32 AM Reply With Quote
Thanks for your help guys.
My conclusions are as follows:
The water temperature sender thread is 1/8 NPT.
The oil pressure sender thread is 1/4 NPT.
GreenGauges.com will supply the required adapters FOC if you order their senders with your gauges.
stevebubs
posted on 10/3/05 at 08:42 PM Reply With Quote
This is the same as the Crossflow and early zetecs so would make sense.
