Author: Subject: injectors?
paul_mcq
posted on 15/3/05 at 07:15 PM Reply With Quote
injectors?
well ppl hows it hanging? haven't been on a while so i thought id ask a question to start back, thinking of moding my car cuz buy the looks of insurance i'll be keeping it for a while, just wondering if u put injectors of a 1.4 into a 1.1 will it make a difference or will it destroy the engine?
Liam
posted on 15/3/05 at 07:24 PM Reply With Quote
Hello...
Well it depends on whether or not the 1.4 injectors are any bigger than the 1.1 ones - they might not be.
If they are they'll squirt more fuel in and your engine will run rich - yay.
Liam
tks
posted on 23/3/05 at 12:54 PM Reply With Quote
bigger
he want to say more cc/sec with bigger
but it still depends on more factors like openening time etc..
tks
The above comments are always meant to be from the above persons perspective.
NS Dev
posted on 23/3/05 at 03:46 PM Reply With Quote
why do you want to put bigger injectors in? What have you done to improve airflow in order to need more fuel.
In any case, if the injectors are different (which I doubt) and you have modded the engine, simply upping the fuel pressure will have the same effect and will be free! Borrow a pressure gauge, check the pressure, then squash the std tin regulator with a g clamp until you have the pressure that you need!
None of this will improve performance, you need air to mix with the fuel!!!!!!!
