Author: Subject: Views on Painting inside of a Sump
DrEagle
posted on 16/3/05 at 09:39 PM Reply With Quote
Just got my sump back from shot blasting.
Do i risk painting the inside with engine enamel?
or am i being thick?
Never be afraid to try something new!
Remember that a lone amateur built the Ark with no budget,
where as a large group of professionals spent millions building the Titanic!
Dave Ashurst
posted on 16/3/05 at 09:47 PM Reply With Quote
Why paint it?
a) Seems like potential future trouble if you do.
b) It won't go rusty if you don't.
in my opinion
hector
posted on 16/3/05 at 09:52 PM Reply With Quote
I would think NOT, you dont know how the paint would react to the oil long term, flakes of paint looming in engine would be in the back of my mind!!
Ben_Copeland
posted on 16/3/05 at 09:53 PM Reply With Quote
Metal plus oil... why paint it ?
Wont rust because of the the oil over it
Ben
Locost Map on Google Maps
Enter Your Details Here
Danozeman
posted on 16/3/05 at 09:58 PM Reply With Quote
Why paint it.. Itl flake off and do your bearings.. and may go gungey with the oil and sod everything up..
Dan
DrEagle
posted on 16/3/05 at 09:59 PM Reply With Quote
ok ok
Im being stupid.
Thanks Chaps
stevebubs
posted on 17/3/05 at 12:17 AM Reply With Quote
powdercoat - yes; paint - no.
but why bother? the oil in it will prevent rust - you don't paint the inside of your block, afterall
the JoKeR
posted on 17/3/05 at 12:38 AM Reply With Quote
Glyptal: This is about as much paint as I would put inside the engine. Although I have no first-hand experience with Glyptal, it has a strong following with a lot of engine builders for use on non-machined areas to create more of a non-porus surface. The thought is that it will help get the oil back into the pan faster. Here's an example of it in use on the top-end of this engine (it's the red stuff!)
[Edited on 17/3/05 by the JoKeR]
__________________________
Jeff
http://www.midwestwelding.com
http://www.locostusa.com/forums/
wilkingj
posted on 17/3/05 at 06:55 PM Reply With Quote
I would NEVER paint inside an engine.
If it comes loose or flakes, or disolves with the oil on it, it will get in the oil and bearings and cause extra wear, or clog oilways needed for lubrication.
Why paint inside?
1. It wont rust inside the engine - Too much oil splashing around.
2. No one will see your nice paint job anyway.
IMHO Its wasted effort, time and money.
Paint the outside if you want.. That I can understand and agree with.
Best Regards
Geoff
http://www.v8viento.co.uk
britishtrident
posted on 17/3/05 at 06:58 PM Reply With Quote
I have seen engines painted inside seemed to work BUT personally I wouldn't do it I have had too many bad experiences with peeling paint in petrol tanks and jerry cans causing havoc.
craig1410
posted on 17/3/05 at 07:21 PM Reply With Quote
I agree, don't paint it...
When I first saw the picture above of the V8 engine with the painted valley I thought it was a picture I had seen before in an engine building manual where someone had painted the inside of the engine with something like hammerite or some of the cheap gungy engine enamel. Anyway, it had all softened and flaked off in large chunks and had completely destroyed the engine due to oilway blockage.
Whilst I agree that it is sometimes a problem with V8's getting oil back to the sump quickly, usually this can be improved sufficiently by radiusing a few edges, drilling a few relief holes (in appropriate places of course) and removing the casting flash. You can also increase oil capacity in the sump or go the whole hog and dry sump it if justified.
Hope this helps,
Craig.
the JoKeR
posted on 18/3/05 at 12:25 PM Reply With Quote
I might paint the lifter valley using the Glyptal, but I'd never do it without having the engine hot-tanked first to remove EVERY trace of oil. This stuff isn't a regular engine paint and has been in use long enough to get a good reputation. It isn't 100% necessary, but I don't think it's a bad idea *if done properly*.
Jeff
tks
posted on 18/3/05 at 02:48 PM Reply With Quote
painting an engine
i even would pain a engine from the outside because in the summer you don't want to give you engine a pair of extra socks?? i see it like a isolator..
TKS
The above comments are always meant to be from the above persons perspective.
Simon
posted on 19/3/05 at 12:37 AM Reply With Quote
As above - wouldn't paint it!
As for V8 oil return, as Craig says, plus a bit more. IIRC in Hardcastles R V8 book some people have got quite carried away removing all sand casting marks so valley is quite smooth. Quicker oil removal = better heat dispertion.
Don't paint (for reasons previously given) and it adds mass which may retain heat?
Simon
wilkingj
posted on 19/3/05 at 12:50 AM Reply With Quote
http://www.v8engines.com/engine-4.htm
About 3/4 way doen the page.
If Chris Crane oes not advise it, then Dont do it.
Best Regards
Geoff
craig1410
posted on 19/3/05 at 05:39 PM Reply With Quote
Yes that's the photo I was talking about earlier in the thread, I just couldn't remember where I had read it...
Craig.
coovey
posted on 19/3/05 at 10:35 PM Reply With Quote
i wouldn't dream of painting the inside. asking for trouble in the future.
Plus you'll hopefully never see it again
stephen_gusterson
posted on 19/3/05 at 10:57 PM Reply With Quote
as you cant see inside an engine, why paint it!!!!!! its gonna be covered in oil anyway. while your at it, you could paint the crankshaft too.......
atb
steve
posted on 19/3/05 at 11:24 PM Reply With Quote
oil paintings... just ask van gogh.
clbarclay
posted on 19/3/05 at 11:29 PM Reply With Quote
But I thought the paint I used on my main bearings was oil based so I didn't need to put oil in the sump....
