dpriest
| posted on 20/8/05 at 06:05 PM |
chevy 4.3 v6
hi, i was planning on a BEC but i have an old chevy s10 laying around so i was wondering: will the 4.3 v6 fit in a locost? and if no, what mods would
i have to do to make it fit?, will the rear axle(solid) be too wide?, will the front suspension work?
i havn't built the frame yet, and want to fiberglass my own bodywork to save some money so if the chassis would need to be widend to fit the
axle its not that big of a deal but i was just wondering because i do want it to look like a 7
thanks
Dave
chrisg
| posted on 20/8/05 at 06:24 PM |
You could use the engine, possibly using a plus four inch frame, but the issue really is weight, heavy engines adversely affect the handling.
How much does it weigh?
Chris
jestre
| posted on 20/8/05 at 06:40 PM |
The Stalker runs the Chevy 2.8l with s-10 drive train.
http://www.angelfire.com/biz6/stalkerv6/index.html
[Edited on 20/8/05 by jestre]
jestre
| posted on 20/8/05 at 06:41 PM |
so, most of the suspension and rear end are useuable.
dpriest
| posted on 20/8/05 at 06:43 PM |
im not sure how much it weighs because i have not yet pulled anything from the truck. i know the weight will hurt the handleing but i dont really
intend to do very much track type driving with it so im not to worried. i just want to have fun building it and try not to spend too much money on it.
and i may eventually switch to a bike engine when i have more money.
thanks
Dave
chrisg
| posted on 20/8/05 at 07:26 PM |
The mcSorley plans include larger versions, online. I don't have the link but I'm sure one will be along shortly
Chris
Ronin
| posted on 20/8/05 at 07:41 PM |
They can be found here
dpriest
| posted on 20/8/05 at 07:48 PM |
yep, i have the mcsorley +4 plans but i wasn't sure if the 4.3 would fit, or if the rear axle would be too wide.
thanks
Dave
chrisg
| posted on 20/8/05 at 07:51 PM |
told you!
Chris
dpriest
| posted on 20/8/05 at 08:41 PM |
ok, so if i use the +4 mcsorley chassis can i use the back axle of the s10? or will it be to wide?
and can i use the whole front suspension(not just the upright?)
thanks
Dave
[Edited on 20/8/05 by dpriest]
chrisg
| posted on 20/8/05 at 08:45 PM |
It's tape measure time unless somebody knows The width of the S10 axle?- as a guide uk Capri axles used with a +4 chassis are 52 inches across
the back plates, If it's close to that you could make up the difference in the rear wheel arches.
Chris
dpriest
| posted on 20/8/05 at 09:37 PM |
i just went out and measured it and it is 58 inches wms-wms, and about 54 inches from the back of the brake drums, i assume this is an acceptable
width?
Dave
Mikeo
| posted on 21/8/05 at 12:53 PM |
I have also been looking at the S10 for a donor. I think with a +4 (wider) chassis the rear axle will be fine. Plus you can get them with disc
brakes and the parts are cheap. As far as the front end parts I am also planning to use S10 uprights and discs. The Stalker V6 uses S10 components
so we should be able to make them work with the Locost.
Mike
Syd Bridge
| posted on 21/8/05 at 03:05 PM |
The Chevvy V6 is the same as the Buick/Holden thing in Aus. The V8's are easier to fit because they aren't as tall. You'll need a
fairly tall scuttle, and nosecone. Good power though.
dpriest
| posted on 21/8/05 at 04:37 PM |
Mike
Mike, are you useing all of the s10 front suspension or just the upright? i think i am going to build my own wishbones just because the ones on my s10
donor are so ugly.
Also, will the steering rack from the s10 be useable?
Dave
Dale
| posted on 21/8/05 at 04:52 PM |
The stalker as far as I know uses the upright and a chevette rack. The 4.3 is a very torquey motor- I used to have one-. Unfortunatly they require
alot - I mean alot of airflow and cooling- There were alot of problems with them neading rebuilds at around 130k km by then the oil rings had
disintigrated. That was in the Safari and astro vans. Same engine seamed to last forever in the pickups.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
dpriest
| posted on 22/8/05 at 09:43 PM |
bought the trans
i just got back from the junkyard and i bought a 5 speed trans,bellhousing, and the wiring harness for the 4.3(mine got burned) all for $30, now i
just need to go and pull it out of the truck, and get a new clutch.
Dave
