stevebubs
| posted on 18/10/05 at 05:57 PM |
Header Tank Location
Has anyone relocated the header tank to hang off the front of the engine
Is there any reason why this is a bad idea?
Danozeman
| posted on 18/10/05 at 06:04 PM |
Vibration.. Doesnt it have to be highest point of the system?
Dan
donut
| posted on 18/10/05 at 06:17 PM |
Yep, as high as you can go. This is why they are usually put just infront of the scuttle.
stevebubs
| posted on 18/10/05 at 07:04 PM |
High isn't really a problem with a zetec - there are mounting points at the front of the cam belt cover which puts the bottom of the tank above
anything else.
Vibration - is this really a problem?
mark chandler
| posted on 18/10/05 at 08:55 PM |
v6 Mk1 transits had it as standard mounted on a bracket off the thermostat housing.
Hows that for sad..................
Alan B
| posted on 18/10/05 at 09:26 PM |
What Ford for doing it?....
Or you, for knowing about it?
mark chandler
| posted on 18/10/05 at 09:45 PM |
Me for knowing...
The engine sat above the rad so this was the highest most easy to access point.
Nice little oblong copper tank with proper expansion cap on it.
JAG
| posted on 19/10/05 at 08:43 AM |
My header tank is situated under the nose cone near to the front of the engine. It is mounted on the chassis though so no problem with vibration.
Photo in my archive.
Justin
scutter
| posted on 23/10/05 at 05:41 PM |
Just remembered that i'd seen this thread, then I came across this picture.
It'sa cater**m having an engine transplant, may give you a few ideas.
ATB Dan.
