piddy
| posted on 26/10/05 at 07:40 PM |
3.38 diff
Hi. I have sorted my diff problem and now have a 3.38 diff.
However is this suitable for a car engined car?
The 3.38 seems to be sort after, but is this because it's ideal for the bike engine cars?
What ratio would you recommend for a car engine powered car with approx 150-170 BHP?
| posted on 26/10/05 at 07:45 PM |
well, theres a simple and a complex way to look at it.
The simple one is, its a lot less likely that a car engine will need a 3.38 diff, so you may as well sell it for £100ish and buy a 20 pound 3.62
diff.
More complex would be to use the gear clac program to work out your speed in each gear (what engine are you using by the way?!) and see if you really
need it
piddy
| posted on 26/10/05 at 08:01 PM |
Hi.
I have an 1800 Zetec and Intend to fit throttle bodies and and Mega squirt ecu.
I wish i could buy a diff locally for £20.
I was qouted £50 and £100 for a standard 3.62 from two different yards.
[Edited on 26/10/05 by piddy]
tks
| posted on 26/10/05 at 08:07 PM |
it will depend on the wheel size..
And on your box gearings...
If you fit big wheels.. (read this as circumstance then you need an higer diff ratio to keep the same speed and pulling power of your car...
also you can take it rougly..what do i want? top speed or pulling power?
Tks
The above comments are always meant to be from the above persons perspective.
piddy
| posted on 26/10/05 at 08:15 PM |
15" Wheels.
I would say my most important factor would be comfortable cruising at 80.
billy
| posted on 26/10/05 at 08:16 PM |
I ran mine this year with a 3.38 diff with no probs, i did try a 3.9 and 3.6 and found the 3,38 ok. this was with my xe powa
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
| posted on 26/10/05 at 10:36 PM |
geoff is selling a 3.6 diff for £30 at the minute, including some running gear. Cambridge if i remember correctly
