Author: Subject: Peugeot 406 Engine Identification
Ben_Copeland
posted on 6/11/05 at 04:09 PM Reply With Quote
Further on from a post i made a while ago about a knackered peugeot 406 HDi engine, i now need to replace the engine, but i need to find out which engine is in it... the 90 bhp or the 110 bhp version.
Does anyone know a sure fire way of telling ?
Also, when i find out and swap the engines, would i need to swap ECU's, etc? ??
Thanks in advance!
Ben
Locost Map on Google Maps
Enter Your Details Here
Ben_Copeland
posted on 6/11/05 at 04:33 PM Reply With Quote
Well i know theres a 110bhp 2.0L HDI engine and I know theres a 90 bhp 2.0L HDI engine.
The 2.2L might well be 110bhp, and i definately know its not a 2.2L
Plus my dad's got a 2.0L HDI 110bhp, but it's not here to look at and compare.
Was a reply to a reply, but it's gone!
[Edited on 6/11/05 by Ben_Copeland]
Ben
ch1ll1
posted on 6/11/05 at 04:35 PM Reply With Quote
2.0L HD1=
dw10ated (RHZ)=110 HP
dw10td (RHY) = 90HP
2.2D HDI=
dw12ated (4HZ)=133HP
(engine code)
hope this helps
Ben_Copeland
posted on 6/11/05 at 04:38 PM Reply With Quote
Thanks ch1#1 i'll see if i can find an engine code on it.
Any ideas on the ECU ??? can it control another engine, or would it be security locked to a certain engine.
Or would it just have security for ignition, etc. meaning i can keep the original ecu
Ben
ch1ll1
posted on 6/11/05 at 04:48 PM Reply With Quote
not too sure on the ecu
the last time i played with one it also controlled the shut off valve on the back of the diesel pump,
also some use this for the alarm system, so you may have to swap pumps if your going that way!
the engine code can be found
if you look to the left of the oil filler below the diesel injectors on the engine not the head i think !
not 100% on that but think so
[Edited on 6/11/05 by ch1ll1]
Ben_Copeland
posted on 6/11/05 at 05:03 PM Reply With Quote
Tried to find it, but its too dark/cold/wet to see where it is... plus i cant be arsed atm
CHeers for the help, i'll see if i can get someone to sell me an engine with ECU, just in case
Ben
big_wasa
posted on 6/11/05 at 05:30 PM Reply With Quote
errr will try again i new i should of checked before posting doh....
3 models as said the DW10td ie 90 bhp is non-intercooled and the DW10ated 110 bhp is intercooled..
Again I think
One thing I do know is the engines in these are not cheap due to the demand from taxi drivers
Ben_Copeland
posted on 6/11/05 at 05:44 PM Reply With Quote
Theres a few on ebay for £250, couple for £450. I'm hoping the owner of the car can actually find the V5 for it... hoping it'll say on that, so i dont have to go searching !
But they cant find it
Ben
ch1ll1
posted on 6/11/05 at 06:10 PM Reply With Quote
when you open the bonnet is there an intercooler looking at you or not?
Ben_Copeland
posted on 6/11/05 at 06:35 PM Reply With Quote
There isn't one on top of the engine ???
But i thought it was only the older style 405's that had that ?
My dad's 406 HDi 110 doesn't have an intercooler on top of the engine ?????
Or am i missing something ?
Ben
big_wasa
posted on 6/11/05 at 06:41 PM Reply With Quote
erm it should be on the front of the car ,to the left of the rad.....
Just had a look on ebay and I couldnt find one for less than £450 and thats with out ancileries ?
[Edited on 6/11/05 by big_wasa]
Ben_Copeland
posted on 6/11/05 at 06:52 PM Reply With Quote
Yeh, was going to say...
I'll have a look tomorrow.
Ben
Ben_Copeland
posted on 6/11/05 at 07:09 PM Reply With Quote
Needs Injectors, Which I've Got
Waiting on Mileage Confirmation
Ben
ch1ll1
posted on 6/11/05 at 08:50 PM Reply With Quote
that should do the trick!
big_wasa
posted on 6/11/05 at 09:08 PM Reply With Quote
Worth noting that both sellers have Zero feedback......hmmmmm with other traders doing them at £450....hmmmm
I did see the one at 25 quid but whats the reserve ?
Didnt look at the 306 just the 406 tho..
minordelay
posted on 6/11/05 at 11:09 PM Reply With Quote
Hi there
ECU for a 90 bhp will not work with a 110 bhp motor turbo, on the 110 bhp motor turbo is electronically regulated. Suppose you could use the type to suit and swap as necessary.
I have 10 + years of pug experience if you are stuck.
Ben_Copeland
posted on 7/11/05 at 08:21 PM Reply With Quote
Well they found the V5 and it's a 90 bhp engine. So guess thats the engine i'll have to get for it. Save messing about.
I'm a bit wary of the cheaper ones. DIdn't notice the zero ratings tho !!!
Cheers, minordelay i'll keep that in mind. As long as i can use the 90 bhp ECU with any 90bhp engine thats all that matters,
Ben
davidwag
posted on 7/11/05 at 09:52 PM Reply With Quote
Hi,
Peugeot use the engine code as part of the VIN digits 5,6 &7 IIRC.
Easier than searching for it on the engine block.
Ben_Copeland
posted on 11/11/05 at 03:42 PM Reply With Quote
Anyone know if the citreon version fits straight in ?
Ben
ned
posted on 11/11/05 at 03:55 PM Reply With Quote
not directly related but beware they may be different if they do/don't have aircon, i had an earlier mech inj diesel 306 and had to replace the sump once, got one from a zantia but the aircon mounts and general shape were different.
Ned.
beware, I've got yellow skin
Ben_Copeland
posted on 11/11/05 at 07:47 PM Reply With Quote
oh balls.... will it never end
Ben
