| posted on 19/12/05 at 11:34 AM |
resource for 32 mm radiator hoses?
When I tilt my radiator forwards, I will need different length nad shape hoses - the lower one may still fit.
I have measured radiator, WP and thermostat to be 32 mm.
Anyone know of a site that lists radiator hoses diameters/sizes/shapes so I know which cars/model I will need to buy. (not looking to bling it out
with samco )
RazMan
| posted on 19/12/05 at 11:47 AM |
If you give CBS a look, they have some very competitive prices but are rather limited to straight or 90 degree bends. They have very long legs though,
so you can cut on the bend to create your own layout.
Worked for me and a tenth of the price of Samco too.
Raz
| posted on 19/12/05 at 11:56 AM |
link?
lewis635
| posted on 19/12/05 at 12:08 PM |
Try MNR they had some good deals in this thread
hoses
| posted on 19/12/05 at 12:11 PM |
halfords do flexible hose in 32mm for quite cheap, about £10 or less. Depends what your time is worth looking for an alternative! it can also be had
with different bores at each end, and can be tied in knots without kinking.
| posted on 19/12/05 at 12:20 PM |
that's the convoluted stuff, known as the hose from hell??!?!?
I'll consider that as the last resort.
Nearby is a car parts place that has catalogue with the info. I am after - I guess I'll need to walk over there to look in their book again
RazMan
| posted on 19/12/05 at 12:21 PM |
CBS hoses link
ps I would avoid the convoluted stuff - it has a restrictive effect on flow
[Edited on 19-12-05 by RazMan]
Raz
Volvorsport
| posted on 19/12/05 at 12:58 PM |
silicone or black rubber ? i have a cheap supplier of silicone hoses .
www.dbsmotorsport.co.uk
getting dirty under a bus
joolsmi16
| posted on 19/12/05 at 01:39 PM |
hoses
the quickest way is to go down halford my local branch has a large range and with a bit of luck ask for a trade card and get upto 1/3off.
Jeffers_S13
| posted on 19/12/05 at 01:42 PM |
Just go to your nearest scrappy with an idea of what you need regards bends and diameters etc and pilfer what you need from whatever is around and
then mix and match once you get home, I got an armful for about a tenner. For straights you can use thin walled steel tube.
| posted on 19/12/05 at 01:47 PM |
how cheap? To give you idea, have a look at the thermostat housing post in this forum.
If I use the other 'stat housing, I may get away with a stright hose but reckon one with 135 degree bend will fit better.
the lower radiator hoses comprises two pieces with a tube - these can be two 90 degree hoses joined (as currenlty) or perhaps two 45 degrees.
All the hose is 32 mm which makes life easier.
DavidC
| posted on 19/12/05 at 04:49 PM |
If you're after hoses you really should call Highbury Hoses. They do silicon hoses, made to order. The can do practically any size and form :180
degreees, t-pieces, 90s, 45s, reducers or combos off all the above.
Their prices are also cheaper than the Samco equivalents. Seeing as the parts are made to order, you get exactly what you need, no mix-n-matching
neccessary.
Highbury Hose Ltd
Unit 6, Viking Business Centre, High Street
Woodville
Swadlincote
DE11 7EH(Road Map)
Derbyshire
Tel: 01283 217750
DC
