jock
posted on 3/1/06 at 04:01 AM |
4 age v zetec
4age whot is it out of .i was going to fit a zetec but it seems to sit high is 4age? lower .is the sump tin .i did mk1 escort with zetec fitted
sierra cvh sump .
crassfc3s
| posted on 3/1/06 at 07:19 AM |
well in the us the 4age came in toyota corollas and toyota mk1 mr2's
stevebubs
| posted on 3/1/06 at 09:22 AM |
same in the uk...
Schrodinger
| posted on 3/1/06 at 02:09 PM |
Check out the cost of the bits you need before you buy the engine though as some parts can be a bit pricey but the 4Age only comes in 1600 guise.
try RAW Engineering.
Keith
Suffolk
crassfc3s
| posted on 3/1/06 at 08:42 PM |
here in the us the 4age is a very cheap motor somewhere in the range of 3-400 for a longblock running with good compression. theyre also very easy to
modify i have a buddy who made a turbo exhuast manifold and did all the work himself to turbo his car for less than 1000 dollars.
