<<  1    2  >>
Author: Subject: 51mm / 2 inch hose...
paulf
posted on 7/2/06 at 08:20 PM Reply With Quote
I use Corby hose and hydraulics in geddington road Corby.
I bought a meter of 38mm id rubber hose for my throttle body mountings and paid £7 for it. It is rubber but was told it would be ok for my application , even if it degrades it is cheap enough to replace when needed. I dont believe silicon is any more petrol resistant and maybe less so than some rubber.
Paul.
Worth a try as on your route between Peterboro and Leamington.
Paul
Originally posted by muzchap
OK HERE's the PRICES
They do 48mm Internal Diameter black pipe @ £13.80 per metre
They do 51mm Internal Diameter black pipe @ £14.30 per metre
Oh this is not Grifflex, this is Radiator Hose.
They can deliver, and minimum length is 1 metre.
Therefore if we want to buy bulk we'll need even numbers as 0.5 metres to fit them should be more than adequate.
Murray
[Edited on 7/2/06 by muzchap]
muzchap
posted on 8/2/06 at 08:15 AM Reply With Quote
Cheers Paul :-)
Yeah used to frequent Corby, had a girlfriend there
She used to hold up the umbrellas at motorbike races... 5ft 2, size 8 and 32DD
I constantly ask myself why did I end it? :-(
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Chris_G
posted on 6/3/06 at 02:30 PM Reply With Quote
Murray,
did you ever get this sorted? I'm about to be in exactly the same position with my GSXR T/B's. What did you end up using or is you bulk buy idea still in limbo?
Chris
Murray
Now finished! Xflow-Zetec swap with GSXR TB's and Megasquirt.
muzchap
posted on 6/3/06 at 02:48 PM Reply With Quote
check your U2U ;-)
Volvorsport
posted on 6/3/06 at 07:14 PM Reply With Quote
if you go round all the six cylinder 960 volvos in scrap yards , thats exactly how all the manifolds are held on , and its 2 inch .
or you can try and contact PDM hose , they were my silicone hose supplier before i switched codes
www.dbsmotorsport.co.uk
getting dirty under a bus
<<  1    2  >>
