darrens
| posted on 16/2/06 at 02:28 PM |
RV8 & SD1 Clutch probs
Hi,
Woundering if anyone can shed any light on this.
I have an RV8 3.9 (was 3.5) with an 3.5 SD1 flywheel attached. The gearbox, which as fas as I can make out has the marking 17A0161826 D (on the side)
making it I think from a 5 speed 2300/2600 (not sure on this though, as the codes I've found don't have the G infront). My problem is do I
go for a 3.5 ltr clutch kit (but which one as their are two early and late) or a 2300/2600 clutch.
Hope someone can help
[Edited on 16/2/06 by darrens]
darrens
| posted on 16/2/06 at 02:44 PM |
no need, rimmerbros came up trumps
| posted on 16/2/06 at 02:45 PM |
and?????
froggy
| posted on 16/2/06 at 04:08 PM |
darren your box came from an 84 vanden plas efi v8 i checked today from the guy i bought it off
darrens
| posted on 17/2/06 at 04:27 PM |
According to Rimmerbros, all clutches will fit, the diff between the two V8 clutches is that one is self centreing the other isn't.
darrens
cheers for that, any luck on that dizzy?
wilkingj
| posted on 17/2/06 at 08:38 PM |
There are two clutches on RV8's
9" and 10.5"
You cant use a range rover / Landy V8 flywheel which has the 10.5" clutch as it wont fit in a SD1 bellhousing.
I used a P6 flywheel, (or SD1) with a 9" clutch.
I am fairly sure the Land Rover Diesel (Tdi 200) clutch and cover fits. but the release bearing wont. £53 ish from paddockspares.com (Not 100% there,
but Rimmers is £125+) I have measured them side by side and they look the same, sizes etc
However, You musy use the SDI Clutch arm, release bearing and carrier, pivot pin, and slave cylinder.
Rimmers want the earth for a Clutch Slave cylinder. I got mine from www.brakeparts.co.uk much cheaper.
The Master cylinder, I used a Land Rover Series 3 Clutch master cylinder from www.Paddockspares.com for £19 (genuine Girling, or £9 for the Pattern
one) , not the £75 that Rimmers wanted. You just need a "saddle clamp" with an imperial thread from Europa spares to make it fit. Mine
works fine in my viento.
Also fit a new Pivot pin and Arm, they wear out quickly. See my piccys of the worn pivot @98K miles. Release bearing melted and pushed through the
clutch.
There are some piccies in my archive.
Best Regards
Geoff
http://www.v8viento.co.uk
froggy
| posted on 18/2/06 at 08:57 AM |
darren remind me do you need the lot dizzy and amp ,il go and have a search today and il dig out that little bit for your gearchange too . were them
manifolds any good to you?
darrens
| posted on 19/2/06 at 09:06 AM |
dizzy and amp if you can. The manifolds were useful for lining things up, but to be honest their gonna be surplas soon, so if you want them back let
me know, or anyone else wants em for that matter.
