| posted on 6/3/06 at 10:40 PM |
ford zetec heads and blocks
are the cylinder heads and blocks for ford zetec engines interchangeble?
1600/1800 and 2000? (in particular early ones circa mid 90s.
and of less important but still of interest! the later smaller capacity ones? 1.24/1.4?
DIY Si
| posted on 6/3/06 at 10:42 PM |
Don't know myself, but if they're anything like other ford engines you can probably change just about most things over.
zilspeed
| posted on 6/3/06 at 10:53 PM |
1.6 has small bore and 26mm valves. So heads from bigger versions don't fit.
The 1.25 and 1.4 are Zetec se which is a Yamaha designed engine - completely different from the original zetec. The Zetec SE also has a
different bellhousing pattern to most other 4 cylinder Ford engines. (As does the Duratec).
