Ian Pearson
| posted on 16/3/03 at 09:46 AM |
Leaking Type 9 Gearbox.
Any of you rebuilt a Type 9? My gearbox loses serious qaunities of oil where the splined output shaft exits at the rea of the box. I'm not sure what
seals could should be replaced. Any help/ info etc would be much appreciated.
Many thanks, Ian.
Mark Allanson
| posted on 16/3/03 at 10:28 AM |
Its usually the seal at the rear, the input shaft of the propshaft basically bungs up the rear of the box and the rear seal prevents the oil leaking -
as the prop turns (mine doesn't do that yet!), it wears the seal. It is a simple pull out and press in with a large socket. Cheap and simple
Ian Pearson
| posted on 16/3/03 at 03:53 PM |
Thanks Mark,
I'd presumed it wasn't going to be that easy! I'll give it a try.
Cheers, Ian
JohnFol
| posted on 17/3/03 at 09:37 AM |
Mark, is not that simple once the side panels are done and the axle is in place .. .
I have just fitted the engine, so I guess it would be a false economy not to change the seal now.
Mark Allanson
| posted on 17/3/03 at 12:29 PM |
For the price of a seal and 5 mins work, I think I will pop one in as well (it had not crossed my mind, perhaps we should have a "1001 things to
remember before you bolt it all in" thread!)
David Jenkins
| posted on 17/3/03 at 01:08 PM |
I changed mine for the cost of a few Pounds. Mind you, the old one was ragged!
JohnFol
| posted on 17/3/03 at 01:24 PM |
David, are you a Pogonophora
David Jenkins
| posted on 17/3/03 at 02:01 PM |
...and proud of it!
DJ
David Jenkins
| posted on 17/3/03 at 02:07 PM |
...I should that I have a beard - not that I am a bearded worm! (Guess who just looked on Google...)
DJ
JohnFol
| posted on 17/3/03 at 02:09 PM |
Always the good source of words to slip into emails to the boss
http://www.worldwidewords.org/weirdwords/
David Jenkins
| posted on 17/3/03 at 02:17 PM |
...one of my favourite time-wasting sites!
Sorry boss, I didn't say that, honestly...
DJ
Ian Pearson
| posted on 17/3/03 at 07:55 PM |
Replaced the seal today, hoisted engine/gearbox combo in the air, stood gassing for 5 mins. Result: oil everywhere!! It seems that the seal I replaced
seals around the drive shaft!! Komplicated stuff this mekaniking!!
Mark Allanson
| posted on 17/3/03 at 08:32 PM |
Yep, the prop input shaft acts like a bung!!
