Author: Subject: Hoses... sources??
chrsgrain
posted on 29/3/06 at 06:38 PM Reply With Quote
Hoses... sources??
I'm having some problems sourcing the hoses I need to get the cooling system sorted... and that's about the only thing between me and turning the key for the first time!!! (electrics now pretty much OK I think!)
I'd like to get all black simple (cheap) not logo'd hoses in a variety of sizes (38, 32, 20 and 8 id) in short straight and angled pieces (mostly 90's but maybe a couple of 45's, thinner pipes will probably bend enough as straight lengths I hope)... trouble is I'm struggling to find anywhere who has any.... Tried CBS, Europa and RS - but nothing really. Local motor factors want parts numbers and makes/years which is no good...
has anyone got any good ideas??
Chris
greggors84
posted on 29/3/06 at 07:00 PM Reply With Quote
Halfords do universal flexy hose in various sizes and reducers.
If you want silicon, try highbury hose 01283 217750, im sure someone told me they make them for samco, just without the name printed on.
the_fbi
posted on 29/3/06 at 07:28 PM Reply With Quote
http://www.siliconhoses.com/
ned
posted on 29/3/06 at 07:46 PM Reply With Quote
Chris,
Why so many sizes of hose? I'e pretty much sorted my cooling system this week and i've only used 32mm for the main to and from engine/radiator hoses and 10mm (sorry 9.5) for connections to the header tank off some fabricated t-pieces.
latest in my archive under 'build march 06' shows how i've routed it.
Ned.
beware, I've got yellow skin
mark chandler
posted on 29/3/06 at 07:49 PM Reply With Quote
Landrover Series II & III bottom rad hose, They have quite a few bends that you can chop out and costs pennies.
Cheers Mark
mark chandler
Cheers Mark
907
posted on 29/3/06 at 08:03 PM Reply With Quote
Hi,
They have a book in my local factors with diagrams in.
I just spent half an hour looking through it and ordered what I thought would fit.
Paul G
chrsgrain
posted on 29/3/06 at 08:04 PM Reply With Quote
The LR ones sound good I'll look for some to play with...
I think my engine has different hoses to yours Ned! The main water 'out' is from a 38mm hose which curls round the 'back' of the engine, the water 'in' is 32mm. Radiator main pipes are 32mm. The heater hoses are 20mm and the breather from the radiator is 8mm!!! Did you blank off the heater ports? I'm going for a black and silver engine bay so could do with black hoses.... and didn't want to pay for silicon - though actually might end up easiest!
I'm planning to do the plumbing as in the sbd diagram here
Chris
RazMan
posted on 29/3/06 at 08:36 PM Reply With Quote
Go to your local motoer factor who stocks Gates hoses and have a flick through the Gates catalogue. They show all the sizes and have reducers if required.
I sorted all of my plumbing with a dozen 90 degree bends and hose joiners from Rally design. Looks neat and business like.
Raz
ned
posted on 29/3/06 at 09:05 PM Reply With Quote
yes, that how mine is done, minus the heater outlet and the inlet manifold bleed. my water pump outlet is only 32mm, don't understand where you're getting 38mm from ?!
Ned.
nitram38
posted on 29/3/06 at 09:23 PM Reply With Quote
Thinkautomotive ? look em up on the net
chrsgrain
posted on 29/3/06 at 10:16 PM Reply With Quote
Ned,
I'm not sure why, but the water pump outlet is 38mm diameter! I've checked lots of times and even used my new fancy digital calipers but it's definately different to the inlet side - which I can't explain.
Oh well!
On nights this week, so will try some other motor factors during the day if I manage some sleep!
Chris
athoirs
posted on 29/3/06 at 10:35 PM Reply With Quote
Try this...
http://www.h-e-l.co.uk/catalogue/other%20hoses/other_hoses.htm
I've used them and they are cheeeep too
posted on 30/3/06 at 09:50 AM Reply With Quote
look in nfs - they do long lengths of 90 degree hose in suitable diameters (better than the halfords corrugated donkey knob hoses)
chrsgrain
posted on 30/3/06 at 10:32 AM Reply With Quote
Hmm,
thanks for all the replies - it looks like I was just being over optimistic about costs for this bit - just need to bite the bullet and get ordering I suppose.... just don't want to cock up the measuring now!
Chris
PS - obviously being a bit thick - but who are nfs!!??
[Edited on 30/3/06 by chrsgrain]
EViS
posted on 30/3/06 at 06:32 PM Reply With Quote
Really?! How much is this bit (just hoses?) costing you?
chrsgrain
posted on 31/3/06 at 12:59 AM Reply With Quote
As advised above went to Motor Factors today - differnt one from usual, who had a Gates catalogue, and ordered a load of stuff that should be ideal - they had loads of pictures with dimensions.
My estimate for silicone for the job was £120 ex VAT, got all the stuff from Gates for £65 inc VAT - and should have a few spare bits if I didn't measure perfectly - very happy!
Thanks for the help guys...
Chris
