Author: Subject: c20xe distributor?
david duncan
posted on 21/4/06 at 09:10 PM Reply With Quote
c20xe distributor?
Which distributor is required to run 45's on an xe?
Fatgadget
posted on 21/4/06 at 09:20 PM Reply With Quote
Megajolt.
david duncan
posted on 21/4/06 at 09:24 PM Reply With Quote
megajolt
Got one?
ned
posted on 21/4/06 at 09:28 PM Reply With Quote
a standard dizzy will work with a 2d or 3d ignition only ecu or you can use the old mk2 cavalier 1.6 dizzy if you can find one with its loom and ignition/amplifier unit
Ned.
beware, I've got yellow skin
billy
posted on 21/4/06 at 09:30 PM Reply With Quote
hi dave, to get this working for you, you need to get a dizzy from a mk2 cav and it will bolt on the back of the head. there are different types on diff models, the one you need has a black plastic peg inside which locates in the cam ( if i rememder ) bit hard to get now. best get a old mbe ecu or summit to do the ignition. im using a old 916 mbe. cheers
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
