BKLOCO
| posted on 3/5/06 at 06:49 PM |
Blue smoke NOT
Well Bu**er me!
Or as a certain grumpy old git would say "I don't believe it"
After all the dramas of my engine belching blue smoke when cold, tonight this happened.
Mike (RazMan) came round and I says: "Wanna see this blue smoke?"
"Yes" Says Mike.
I start the engine and......
Yep you guessed it....
Not a trace of blue smoke!!!!!
WTF is going on?
I left the car, overnight, on ramps under the front wheels, although it had been level for about an hour before I started it.
Could this be a factor?
This is getting more baffling by the minute.
Sticky valves perhaps?
muzchap
| posted on 3/5/06 at 06:56 PM |
Perhaps you'd overfilled? as mounted at a different angle and now all the excess oil has burnt away?
I dunno - sounds weird - but good luck! Hope it's stopped for good
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
nitram38
| posted on 3/5/06 at 07:11 PM |
Make sure that the oil breather system is working with no blockages.
If you have not over-filled it, then I would look here first.
Johnmor
| posted on 3/5/06 at 08:17 PM |
Sump
Have you altered the sump?
Remember the dip stick measures oil in relation to the maximum height on the crank, if you alter the sump,and change the dip stick , the oil capacity
can change and the level of the oil becomes too high resulting in similar problems and oil seal leaks.
Keep the old dipstick as it will work with that block and crank.
Just a thought.
RazMan
| posted on 3/5/06 at 09:20 PM |
I reckon the stress of your forthcoming SVA test is making you hallucinate Brian
Raz
