Author: Subject: oil filter thread size
trogdor
posted on 8/5/06 at 10:01 PM Reply With Quote
hi, does anyone know what the oil filter thread size of a 1800 zetec is? its a xr3i 1800 from 1992. i would check myself but the engine is miles away at the mo!!
chriscook
posted on 8/5/06 at 10:50 PM Reply With Quote
Filters often have the thread size printed on the can. Trip to your factors/Halfords if its closer than the engine?
posted on 9/5/06 at 07:58 AM Reply With Quote
I reckon it is 3/4 UNF; I can check for sure tonight (if I remember....)
ned
posted on 9/5/06 at 08:23 AM Reply With Quote
i tried loads of filters at halford for my remote filter head and all the ford ones i tried were 3/4" unf..
Ned.
beware, I've got yellow skin
Mal
posted on 9/5/06 at 11:25 AM Reply With Quote
Oil Filter Threads
Something I found to be aware of is that the threads on some filters are M20 and will screw onto 3/4"UNF engine studs, but with limited depth of engagement. I tried a short Renault filter, Halfords HOF266)which would clear my steering column on two Zetec oil pumps. On the one it would grip, but on the other it gave stripped thread symptoms. When I investingated with a vernier caliper I found a slight difference in the OD of 2 male threads was just enough to grip on the one pump, but the engagement was very poor due to the 1mm difference in the thread diameters.
Mal
posted on 9/5/06 at 11:51 AM Reply With Quote
did you look at: HOF 249, large dia. bidy but short, 3/4 UNF thread.
Schrodinger
posted on 9/5/06 at 11:56 AM Reply With Quote
If you are looking for a shorter filter try one from the fiesta as that is much shorter than the standard Zetec filter.
trogdor
posted on 10/5/06 at 01:26 PM Reply With Quote
i am atcually looking to fit a sandwich plate for an oil cooler.
i found one on ebay that also allows me to plumb in a oil pressure gauge as well.
i may need a shorter filter so thats a good tip! cheers!
