Author: Subject: Cooling...
stevebubs
posted on 31/5/06 at 08:06 PM Reply With Quote
Cooling...
OK...trying to figure out if I have a cooling problem or not and having a brain fade day.
With an ambient temperature of 15 degrees, and trundling around at 30ish, car seems to keep cool quite happily.
Sat on the drive idling with an ambient temperature of 15 degrees, temperature heads to 100degrees, fan kicks in and cools back down to 90. Fan turns off, goes back up to 100, fan kicks in, goes back down to 90
Does this sound OK..bearing in mind the car needs to withstand the heat of Le Mans in 2 weeks.
Stephen
mookaloid
posted on 31/5/06 at 08:07 PM Reply With Quote
sounds as if it is doing what it should do to me
irvined
posted on 31/5/06 at 09:06 PM Reply With Quote
Sounds about right to me too,
http://irvined.blogspot.com
Hellfire
posted on 31/5/06 at 09:09 PM Reply With Quote
What sound? I hear no sound?
Reads ok to me too
stevebubs
posted on 1/6/06 at 07:43 AM Reply With Quote
Similar results to here, too....http://www.emeng.gentlyhosting.co.uk/Cooling/Part5.htm
