Author: Subject: 711 engine
davrus
posted on 19/7/06 at 10:03 PM Reply With Quote
711 engine
Hi ya , can anyone confirm that a 711m engine in a 1600 or a 1300
Many thanks
davrus
dave-69isit
posted on 19/7/06 at 10:11 PM Reply With Quote
711 engines
ford did both in 711 block
RichieW
posted on 19/7/06 at 10:29 PM Reply With Quote
yes the 711 could be either. If you have a particular block in mind then check the casting marks. If it says 711M-6015-AA its a 1300 or possibly even an 1100. The 1600 has 711M-6015-BA on it.
[Edited on 19/7/06 by RichieW]
davrus
posted on 19/7/06 at 11:02 PM Reply With Quote
thanks doods
i thought the man who told me 711m was only a 1.6 was full of s**t
stevebubs
posted on 20/7/06 at 12:16 AM Reply With Quote
711M in my garage is definitely a 1300 block.
As mentioned - check the castings...
posted on 20/7/06 at 08:04 AM Reply With Quote
must be the same man who sold me mine, said it was 16700 but turned out to be 1300, cheaper road tax so not all bad.
AA is a 1300; BA is 1600.
MikeRJ
posted on 20/7/06 at 08:37 AM Reply With Quote
I just bought a 711M 1600 engine and a set of +90 pistons to take it up to 1690. However, when I stripped the engine I was somewhat dissapointed to find it's had liners put in so can't re-bore it. Slightly odd as pistons and bearings are standard size and engine looks like a low mileage lump.
Did Ford ever line blocks to salvage porous castings at the factory?
paulf
posted on 20/7/06 at 11:47 AM Reply With Quote
Yes they did sometimes , I came across a few when working for a company that reconditioned engines.The worst thing they did though was to bore main bearing caps over size to salvage badly machined blocks , many people have been caught out by that and the over size mains are more expensive than standard ones.
Paul.
