Author: Subject: which sump plug washer?
cadebytiger
posted on 23/7/06 at 01:46 PM Reply With Quote
I ahve a new sump plug but i don't knwo which washer i should be using
There is a plastic on or a metal on with a rubber inner bit??
it's a pinto
I am changing it as the last one had been put i with no washer and is thus leaking!!
Thanks chaps
Rupert
ruskino80
posted on 23/7/06 at 01:57 PM Reply With Quote
use the rubber one but make sure both surfaces are clean and flat -run a smudgen of oil onto the rubber prior to putting it in.-do not over tighten just a nice nip.
cadebytiger
posted on 23/7/06 at 01:59 PM Reply With Quote
Thanks very much! Will go and do it this evening!
Rupert
posted on 25/7/06 at 07:27 PM Reply With Quote
The plastic one was fitted as standard by Ford
cadebytiger
posted on 25/7/06 at 08:30 PM Reply With Quote
so is the rubber one better???
There was what looked like a very thin one on a sump plug i saw from another engine. the one in the pack i have is prob about 1mm thick
Rupert
C10CoryM
posted on 25/7/06 at 08:44 PM Reply With Quote
Rubber/steel ones are better. The plastic ones tend to loosen off and/or leak. Ive never seen one fall out, but Ive seen them awful loose. I always replace the plastic ones on customers cars when changing oil.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
cadebytiger
posted on 26/7/06 at 07:35 AM Reply With Quote
Great thank you everyone! The metal one it is!
Rupert
