john_p_b
posted on 30/7/06 at 07:27 PM |
omex speed system on a pinto
anyone got one fitted?
was looking at getting a rev limiter to avoid having to worry after missing gears like the other night!
seen the omex speed system which is a rev limiter and shift light in one. it's under a ton so doesn't seem that bad priced?
any opinions or alternatives to it?
cheers
john
built a car, built a home, had a family. lost the family, lost the home, still got the car.
oliwb
| posted on 30/7/06 at 08:03 PM |
Megajolt?? Sorry - had to be done! Oli.
tim windmill
| posted on 30/7/06 at 08:39 PM |
i agree with oli, megajolt is the way to go , built in rev limiter,shift lights and mapable ignition
john_p_b
| posted on 30/7/06 at 09:26 PM |
whats that going to cost me though?!
MikeRJ
| posted on 30/7/06 at 11:29 PM |
I'm almost certain that Megajolt does not have a built in rev limiter, injected cars use fuel cut to rev limit as it doesn't cause
backfires and potnential damage to the cat that cutting the igntion would.
However, you could probably add one on using one of the RPM controlled outputs and a few components.
