JimSpencer
| posted on 14/8/06 at 08:28 AM |
Intermitent Slipping Clutch
Advice needed on odd problem..
Getting occasional clutch slip, only happened a few times.
Spec is 4age on Type 9, cable clutch (light pedal BTW)
when doing a part throttle, mid revs generally lazy change (3rd / 4th or 4th / 5th) get occasional clutch slip.
Full bore max revs haven't had a problem.
Only thing I can think of is a sticking release bearing? Anybody got any ideas (apart from the obvious solution of giving it more death..) or
possible other causes, or better still solutions..
[Edited on 14/8/06 by JimSpencer]
dave r
| posted on 14/8/06 at 08:40 PM |
mine used to act strange, till i re-routed the cable... worked ok when hot and semi molten from the manifold, but wasnt right when cold
the time it took to get ok though, varied from 2 mins to about 1/2 hour ?
may be the same , maybe not
