Author: Subject: GSX-R 1100??
MattCraneCustoms
posted on 19/8/06 at 05:56 PM Reply With Quote
GSX-R 1100??
How possible is it to fit such an engine? I've not entertained the idea of a BEC but when such an engine becomes available, you have to. How would I go about the gearbox? Surely converting a bike into a RWD car is gonna be a serious pain in the a**?? And also I've read on here about dry sumping this engine. Would this be necessary? if so what sort of cost is that gonna amount to?
Regards,
Matt Crane
graememk
posted on 19/8/06 at 05:58 PM Reply With Quote
i think you need to have a look through hell fires build web site so you can get your head around using a bike engine its not as hard as you might think
DIY Si
posted on 19/8/06 at 06:19 PM Reply With Quote
It's actually fairly easy. You need a sprocket converter to allow a prop to run from the output on the bike's gearbox to the rear diff. Otherwise it's mainly as with a car engine, ie exhaust out the side, wiring loom in with ecu....etc etc. Also, if the engine comes with clocks you can use them too.
Sun Tzu, The Art of War
phelpsa
posted on 19/8/06 at 07:34 PM Reply With Quote
Are you talking about the oil/air or water cooled gixer engine?
cloudy
posted on 19/8/06 at 10:36 PM Reply With Quote
even easier if engine is at back
phelpsa
posted on 19/8/06 at 10:59 PM Reply With Quote
Originally posted by CaLviNx
Basically a bike engine is a bike engine if its the older motor your not going to have to worry about plumbing in a raditaor as the older ones are air/oil cooled.
Although you do have the problem of finding a HUGE oil cooler My 40 row mocal jobby should do the job
MattCraneCustoms
posted on 20/8/06 at 06:25 AM Reply With Quote
Thanks for all the reponses guys thats given me a lot more confidence than I had before. One last thing though, how difficult is it regarding clutch / gear shifting?
NS Dev
posted on 20/8/06 at 09:57 AM Reply With Quote
yep, watch oil temps if goign air oil cooled
not sure at all for long term road use, certainly lots of oil cooling needed.
