nib1980
| posted on 24/10/06 at 07:32 PM |
Coolant plumbing - xflow twin carbs
Hi all,
Am I right in thinking the plumbing goes as shown below in my photo?
Many thanks in advance
If not how so?
piccy
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Twin%20carb%20question.jpg
[Edited on 24/10/06 by nib1980]
auzziejim
| posted on 24/10/06 at 07:45 PM |
those are the heater outlets which i believe are the same thread as the 19mm plugs in a pinto block. in stead of connecting the two with a pipe why
not block them both off for a cleaner look?
paulf
| posted on 24/10/06 at 07:52 PM |
Connect them together and also tee into the bottom of your header tank , which ideally should be mounted on the bulkhead above the engine level. This
allows a flow of water around the engine before the thermostat opens and avoids problems with airlocks and overheating, my car is done this way and
has had no cooling problems.
Paul.
