les
| posted on 29/11/06 at 05:39 PM |
r1 carbs-air filter options
Hi chaps,
I have r1 carbs to fit to a 2L zetec, supplied by bogg brothers, any ideas on air filters?
at present I dont even have inlet trumpets just the opening on the carb so can take any route
Les
GavBurns
| posted on 29/11/06 at 05:57 PM |
I have just got one for a fireblade from here: http://www.thepipercrossshop.co.uk/ They was very helpfull and knew what they were talking about.
Go BEC you'll never look back (literally)!!
big_wasa
| posted on 29/11/06 at 06:18 PM |
See Link
You can buy them with a blank back plate. Just cut to size and bond on to the catbs.
A set of R1 trumpet will cost loads, try without to start with.
regards
Danozeman
| posted on 29/11/06 at 06:32 PM |
Iv got one similar to wasa's. The other option is seperate socks.
Dan
les
| posted on 29/11/06 at 07:42 PM |
Hi,
that setup looks great, I take it having no trumpets doesnt really make much difference- and that they can be added later?
also is filter cleanable like k+N?
Les
Stu16v
| posted on 29/11/06 at 08:22 PM |
Please dont do separate socks if possible - they sap power.
Danozeman
| posted on 29/11/06 at 09:02 PM |
I did mean to add that.
Dan
givemethebighammer
| posted on 29/11/06 at 11:37 PM |
Les
Wrong, trumpets make lots of difference. I changed from 50mm ones to 70mm ones on my blackbird carbs and the difference to the mid range was
fantastic.
Basically
Short trumpets = more top end at expense of low end
Long trumpets = strong low and mid range at expense of top end
