madteg
| posted on 26/12/06 at 11:45 PM |
2.5 probe engine
does anybody know if it will mate up to a type 9 box.
gazza285
| posted on 27/12/06 at 12:36 AM |
No, as it is a Mazda based engine. Not to say that you could knock up either an adapter plate or a new bellhousing, but it doesn't fit any of
the available bellhousings.
force10
| posted on 27/12/06 at 08:22 AM |
The Jaguar X type uses this engine and they have their own gearbox so if you can find one that doesn't require re-mortgaging your house you
could use that.
Morgan use them apparently.
gazza285
| posted on 27/12/06 at 11:39 AM |
The X type is either front wheel drive or four wheel drive though.
The modern S type is rear wheel drive though, but availability may be a problem.
goin2fast52
| posted on 27/12/06 at 03:42 PM |
I believe these are different engines. The Probe engine is a Mazda-based K series engine, while the one in the Jaguars are Ford Duratec-based
engines.
Wikipedia is your friend
http://en.wikipedia.org/wiki/Mazda_K_engine#KL
http://en.wikipedia.org/wiki/Ford_Duratec
http://en.wikipedia.org/wiki/Jaguar_AJ-V6_engine
MikeRJ
| posted on 27/12/06 at 03:45 PM |
could use that.
The MX6 used the same engine, but it was never used in a Jag.
