Author: Subject: Carb Mystery - Twin Choke Weber
The Doc
posted on 21/1/07 at 07:33 PM Reply With Quote
And the next question!
I'm a little baffled as my carb has two hose connectors where I would expect there to be only one. Both are situated above the fuel filter on the carb with arrows on the housing above.
What's going on here?
Thanks Again
Mike
ayoungman
posted on 21/1/07 at 07:36 PM Reply With Quote
From your description, I think your refering to the manifold cooling connections. Could you post a picture, I'm sure one of the guys will know. Sorry I could'nt help more.
"just like that !"
UncleFista
posted on 21/1/07 at 07:38 PM Reply With Quote
If it's a DGV/DGAV and the hose connector in question is next to, and identical to the fuel feed, then it's the fuel return.
I've done what most people have done and capped it with a bolt and araldite
Carb still works
Then again it could be the coolant feed for the autochoke, might need a more detailed description or even a pic
[Edited on 21/1/07 by UncleFista]
Tony Bond / UncleFista
billynomates
Are they the supply and return connections for the fuel lines. Thats what they are on mine.
bob
fuel inlet,one is a return which normally people just link with the pipe in making a loop.
The Doc
posted on 21/1/07 at 07:43 PM Reply With Quote
Sounds like the fuel return then.
Would that have gone all the way back to the tank, originally?
Anyway thanks I can sort that now
TA
Mike
