Author: Subject: Mating
speedyxjs
posted on 17/2/07 at 02:42 PM Reply With Quote
Mating
Quick question. Is there any way to mate an engine and gearbox from different cars to each other?
meany
posted on 17/2/07 at 02:44 PM Reply With Quote
where the will, there is a way.
some easier than others.
some have been done already.
what do you have in mind?
speedyxjs
posted on 17/2/07 at 02:48 PM Reply With Quote
jag engine (aj6 or aj16) to probably type 9
Pezza
posted on 17/2/07 at 03:07 PM Reply With Quote
Would a type 9 take the power and torque from that lump?
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
speedyxjs
posted on 17/2/07 at 03:19 PM Reply With Quote
Not sure. know of anything readily avaliable that would?
davidwag
posted on 17/2/07 at 03:23 PM Reply With Quote
How about a Jag gearbox?
Surely they can't have all been autos
Davidwag
speedyxjs
posted on 17/2/07 at 03:25 PM Reply With Quote
Iv looked at that and there arnt really that many and they're quite expencive
SeaBass
posted on 17/2/07 at 03:27 PM Reply With Quote
The original Jag box?? I'm sure Pluto is smaller than those though - no longer being a planet.
If your prepared to package the engine then the box shouldn't be that much more hassle.
fesycresy
posted on 17/2/07 at 03:55 PM Reply With Quote
You need a Getrag box from a BMW 7 series (the one with the detachable bell housing) or a Supra box.
You then need a bell housing. Speak to Realm Engineering.
Master cylinder, slave cylinder, clutch etc etc. Not cheap.
Click - Realm
Lyn.
907
posted on 17/2/07 at 04:43 PM Reply With Quote
Sorry to be vague but I think some Jags used the Getrag.
Also, one of the kit companies, maybe Luego, made a Jag engined 7 with a Getrag box.
I know Lotus used them, as the Eclat engine I'm using has it's original Getrag box into
which I've fitted a hydraulic concentric clutch unit (ex Mundano)
Paul G
major
posted on 17/2/07 at 06:38 PM Reply With Quote
I have also posted this in an earlier reply
" The getrag 221 is the rwd gear used in the lincoln ls and the s type jag (3l). The gearbox internals are mostly form the manuals used in BMW M3. The gearbox won't directly bolt up to a Duratec 25 V6. There are several holes missing on a Dura 25 and some of the holes in the dura 25 are shifted 1 or 2 cm. The st220 mondeo and the jag are using a dura 30. The initial design of the duratec V6 was from porsche, went to cossworth and ended up in different cars (mostly ford related)
