Author: Subject: Exploded diagram of a sierra 4x4 gearbox. Plez
goodall
posted on 16/3/07 at 02:24 PM Reply With Quote
Exploded diagram of a sierra 4x4 gearbox, anyone got one? or of any ferguson ff system gearbox
[Edited on 16/3/07 by goodall]
Liam
posted on 16/3/07 at 08:05 PM Reply With Quote
I've got the ford workshop manual for the 4x4. Id doesnt have an exploded view but has various cross sections and drawings of the disassembly process. I'll try find time to scan some if you need them, but basically you just have a normal gearbox, then driven by that is a planetary centre diff (input is planet carrier, rear output is sun and front output is ring) with viscous lsd mechanism. The rear output is straight off the sun shaft, and the front output is stepped off to the side by a chain drive from the ring of the centre diff to an output sprocket.
Liam
goodall
posted on 16/3/07 at 08:19 PM Reply With Quote
its the exact workings of the transfer case part i want to know about, im sorta picturing what it looks like but im not sure, pic would really help if you can get them, thinking this summer i should find a sierra 4x4 and start building
