GazzaP
| posted on 20/3/07 at 01:40 PM |
Crossflow starting
Hi all
I have just got my engine back from being rebuilt again!!
I am having problems starting it when cranking it over there are flames coming out of the carb and when i removed tha air filter the first choke is
jet black. the plugs are black to. I have got a spark and fuel I have checked the cam timing and that is ok could the ignition timing be 180 out?
any help will be appreciated
regards
Gary
www.gmpmotorsport.co.uk
| posted on 20/3/07 at 02:01 PM |
that was my initial reaction.
easy to check, whip out sprk plug no.1, turn engine over by hand a bit, poke a chopstick in the plug hole, turn over a bit more, if chopstic goes up
you have found the comnpression or exhaut strok.e
rpelace chopstick with finger turn over, if you feel compression, you have found compression stroke; wind p until nealr TDC then look at the dizzy -
rotor arm should be pointing to cylinder no. 1.
check timing too.
if you still have problems, then post again. it would then have to be fule that is not so easy to sort.
Mike S
| posted on 20/3/07 at 02:22 PM |
May be a stupid question but are you sure that you have got the firing order correct? 1,3,4,2
Mike
There are more horses' asses in this world than there are horses
procomp
| posted on 20/3/07 at 02:28 PM |
Hi No dont help him he is quick enough having the engine not working will give some others a chance .
But seriously got to be one of the 2 sugested above.
cheers matt
GazzaP
| posted on 20/3/07 at 02:32 PM |
Cheers matt
Thanks every one else for your ideas i will check tonight and post back later
Gary
| posted on 20/3/07 at 03:01 PM |
just a tip; when I was learning the magic trick to start my xflow, I was over choking it resulting in sooted up plugs.
Clean the plugs before trying to start as I found they would not fire when sooted up.
GazzaP
| posted on 20/3/07 at 10:03 PM |
hi all
I hav tried all of the above and still no joy?
please help
thanks
Gary
| posted on 20/3/07 at 10:16 PM |
Start with the basics, check and adjust valve clearances, plug condition and gap , points?, condensor? firing order? With rocker cover off turn engine
in D.O.R. until valves on no 4 cylinder (flywheel end) and "rocking" ie one closing and the other opening. set crank pulley so that timing
marks align. Check rotor arm which should be pointing to no HT lead . If you have a Bosche distributor there is a small groove in the top face which
should be for no one HT lead . Check for carb flooding , rectify as needed. HTH
MikeRJ
| posted on 21/3/07 at 09:58 AM |
Mike
If he has set it at 1,3,4,2 then that will be the problem!
The crossflow has a firing order of 1,2,4,3
