Author: Subject: Running very rich
ditchlewis
posted on 21/5/07 at 07:36 AM Reply With Quote
Running very rich
Hi Guys
Got the car fired up yesterday and it was running rough. Whipped the plugs out and they were black and soot covered so the engine is running very very rich.
I need to tune the carbs, is Colortune still the best way ?
Last question, what size are the plugs on the old Pinto, will I need and adaptor to suit the plugs as colortune only comes with a 14mm plug?
Ditch
flak monkey
posted on 21/5/07 at 07:55 AM Reply With Quote
Pinto is std 14mm plugs.
Colourtune is one of the best home methods of tuning. Allows you to get pretty close.
Sera
http://www.motosera.com
ditchlewis
posted on 21/5/07 at 08:18 AM Reply With Quote
many thanks i will go to halford at lunch time.
ive only had the car idleing for a few minutes and the plugs foul, i would hate to think what it would be running like after half an hour. i would be getting to tha SVA coughing and spluttering
ditch
cadebytiger
posted on 21/5/07 at 08:26 AM Reply With Quote
reading the book i have been using to set up my carbs (ie not an expert myself) it has a whole section on how the plug colour can only help ou fine tune your engine if the engine is set up well and you know it like the back of your hand.
Will read again tonight and let you know exaclyt what is says
flange nut
posted on 21/5/07 at 08:30 AM Reply With Quote
IIRC Flak Monkey is wrong, the plugs for a pinto are something like 18mm, although the the hexagon on the outside is the same as a standard plug spanner.
Geoff
indykid
posted on 21/5/07 at 09:30 AM Reply With Quote
Geoff
it's an 18mm thread, a 19mm socket size, but a 14mm plug.
i'm gonna go out on a limb and say that's the diameter of the insulation.
either way, if you go to look for a plug socket, they're marked 10, 12 and 14mm.
pintos definitely have 14mm spark plugs
tom
David Jenkins
posted on 21/5/07 at 09:34 AM Reply With Quote
If I start my car and let it tick-over on the drive I find that the plugs can be very black. However, if I check them after a good run then they're the right colour (for what that's worth).
You'll have some fun with the colortune - IIRC you've got twin Webbers, so you'll also have balancing to contend with! It does tell you if you're in the right ball-park though.
ditchlewis
posted on 21/5/07 at 12:08 PM Reply With Quote
indy kid has a point, the plug may be a 14mm but the socket is much larger. i've ordered the standard kit which comes with a 14mm plug, and i notice that on some US web sites you can get larger and smaller plugs from colourtune.
David you are right i'm running twin 45 dellortos which will also need balancing at the same time. .
hope this will get it running a bit better
Ditch
paulf
posted on 21/5/07 at 12:34 PM Reply With Quote
The pinto plugs have an m18x1.5mm thread, crossflows, zetecs, etc have 14x1.25mm thread which is what the standard colour tune is.
Have you ran the car on the road or just ticking over in the drive ? .I always found my crossflow sooted up the plugs if just started and allowed to idle before i had it on the road, but was ok when driven normally. I once tried using a colour tune on my MGB but found i could get a better result just by adjusting for best tickover by ear, all it allows is the idle mixture to be set up, so of no real gain for general driving in my opinion.
Paul.
Ditch
britishtrident
posted on 21/5/07 at 06:51 PM Reply With Quote
Geoff
tom
No all Pintos have 18mm Tapered seat plugs, the hexagon AF size is the same as old style 14mm gasket seal plugs.
Modern 14mm gasket seal and tapered seat plugs use a smaller size hexagon.
[Edited on 21/5/07 by britishtrident]
[/I]
britishtrident
posted on 21/5/07 at 07:01 PM Reply With Quote
If it is running that rich either the choke/cold start is stuck on or the float level is to high or the float chamber is flooding.
[/I]
