Author: Subject: Removing the Matrix
posted on 12/8/03 at 05:05 PM Reply With Quote
Removing the Matrix
If i was to remove the heater matrix of my 1600 pinto, do i plug the two pipes, or do i have to link them together?
Whats the best way to plug them, weld or cork?!
Ta in advance!
blueshift
posted on 12/8/03 at 05:23 PM Reply With Quote
do you mean set the engine up so it will run without a heater?
I think the heater control lever opens and closes a valve, so in the cold position nothing flows through the heater. so the engine doesn't require flow and you can seal the hoses. I THINK. maybe not.
not sure about the best way to seal them. epoxy a plate on at the block? I would be scared to weld a block myself, and I doubt a cork would be much cop.
ChrisW
posted on 12/8/03 at 05:51 PM Reply With Quote
On my XR2 I just connected them together. Didn't appear to be a valve to cut off the flow. Runs (and cools) fine!
Chris
My gaff my rules
theconrodkid
posted on 12/8/03 at 08:13 PM Reply With Quote
peice of copper pipe n some hose clips
who cares who wins
pass the pork pies
blueshift
posted on 12/8/03 at 08:40 PM Reply With Quote
epoxy and a plate might be a tiiiiny weeeeeny bit lighter
actualy maybe as much as a semi-weeeeeny bit lighter, if you consider the coolant that won't be in that loop of tube.
please note I am being quite silly.
[Edited on 12/8/03 by blueshift]
posted on 13/8/03 at 08:17 AM Reply With Quote
Cheers all. Copper pipe sounds right, ill have a look and see....
