Author: Subject: Polo Radiator Owners.....
Ferg
posted on 16/6/07 at 08:44 PM Reply With Quote
Did you block the little 10mm-ish vent?? If so, how?
Howlor
posted on 16/6/07 at 08:45 PM Reply With Quote
Took mine back as a bleed to the top of the header tank.
ned
posted on 16/6/07 at 08:57 PM Reply With Quote
found a good sized bolt or screw and wound it in with some araldite
beware, I've got yellow skin
desyboy
posted on 16/6/07 at 09:13 PM Reply With Quote
i wound a thin self tapping bolt into it and left it as a bleed off
David Jenkins
posted on 16/6/07 at 09:16 PM Reply With Quote
Made a tight-fitting little mushroom-shaped plug and glued it into the hole from the inside - the water pressure reinforces the seal.
mark chandler
posted on 16/6/07 at 09:34 PM Reply With Quote
Stuck a tube on it and sent to header tank.
By only having one tube from this to the header you can fill the system from the highest point, but the tank does not have to be the high point.
andyharding
posted on 16/6/07 at 09:40 PM Reply With Quote
Mine is a drain (rad upside down) blocked off with kinked over hose and a j clip.
Are you a Mac user or a retard?
oadamo
posted on 16/6/07 at 10:03 PM Reply With Quote
anyone got the size of one of these rads soz to hijack post
adam
bob
posted on 16/6/07 at 10:23 PM Reply With Quote
here you go
oadamo
posted on 16/6/07 at 10:25 PM Reply With Quote
Originally posted by bob
here you go
thanks
adam
bob
posted on 16/6/07 at 10:26 PM Reply With Quote
I'll give it a proper measure tomorow for overall size.
RazMan
posted on 16/6/07 at 11:08 PM Reply With Quote
I've got a Polo rad which doesn't have a vent - I feel deprived now
Raz
bimbleuk
posted on 17/6/07 at 02:04 AM Reply With Quote
@ RazMan!
I use it as a bleed point but block it with a self taper in use.
Marlon
posted on 17/6/07 at 06:29 AM Reply With Quote
I ran a pipe back to the header tank on mine.
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
Ferg
posted on 17/6/07 at 09:33 AM Reply With Quote
Thanks all! I don't have room to fit ANYTHING on it, but if I cut it down slightly I should be able to screw something in to blank it!
whitestu
posted on 17/6/07 at 09:57 AM Reply With Quote
Small cap head screw in mine
Stu
bob
posted on 17/6/07 at 03:43 PM Reply With Quote
OK i was having a fiddle in the garage so i had a measure up of the polo rad.
Width 480mm this includes the thermo switch area and the top bleed which sticks out 20mm, i have seen the 8mm top bleed cut shorter which helps nose fitment.
Height 340mm
These measurements are total area.
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 17/6/07 at 07:28 PM Reply With Quote
I got bit of pipe fitted to it and doubled it back on it's self and placed a tie wrap around pulled tight
Job's a good un
Martin
Chazzy
posted on 17/6/07 at 08:23 PM Reply With Quote
tail of hose blocked with a set screw, jub clip to keep tight as it leaked a bit to start.
chas
