Author: Subject: 3.36 diff on my R1 MNR good or not?
sonic
posted on 25/11/08 at 09:01 PM Reply With Quote
Just checked my diff as somebody asked me what i was running and it states 3.36 is that good or bad with a R1 engine?
corrado vr6
posted on 25/11/08 at 09:08 PM Reply With Quote
from what i understand its v.good mate and worth a bit!!
[Edited on 25/11/08 by corrado vr6]
Wadders
posted on 25/11/08 at 09:21 PM Reply With Quote
Are you sure it says 3.36?
If its a sierra diff 3.62 or 3.38 are more likely numbers.
TBH any of the above numbers will be ok, lower numbers just gives it more legs.
Al.
oldtimer
This is usually a question that gets lots of "I'll have it if you don't want it" answers. So wheel/tyre/usage dependant , but yes.
bassett
posted on 25/11/08 at 09:42 PM Reply With Quote
I think that its good, Marc at MNR recommended the 3.38 for ours and if yours is 3.36 it will have slightly more top end speed but this is marginal. I think there also non lsd like most but that bit you'l have to check
Adam
sonic
posted on 25/11/08 at 10:03 PM Reply With Quote
Yes it does say 3.36 and also confirmed buy the guy who built it and i bought it off.
It is the non LSD version and i am running 15" wheels with 195-50-15 tyres.
I am using it for mainly road fun but may do the odd track day
PAUL FISHER
posted on 25/11/08 at 10:15 PM Reply With Quote
If it is the 3.36 its most likely to be the 7.5" unit as fitted to the granada's,in this size and ratio they do both the lsd which was fitted to the scopio 4x4's,and the standard diff,which was fitted to the rest of the granada range.
sonic
posted on 25/11/08 at 10:19 PM Reply With Quote
Thanks for the info guy's
I was thinking of changing it to a LSD Cossie type.
Do you think i shoud stick with what i have?
PAUL FISHER
posted on 25/11/08 at 10:29 PM Reply With Quote
Depends really,its a good ratio,but depends if your going to use the car for, any serious track work,then in my opinion I would not be without a lsd.
posted on 26/11/08 at 09:00 AM Reply With Quote
Here we go then, if you don'yt want it., I'll take it off ya!
