madteg
| posted on 1/2/09 at 08:44 AM |
V8 rover ?
Can you fit 3.5 heads to a 3.9 block as i have a good 3.9 block and a 3.5 with u/s crank
mark chandler
| posted on 1/2/09 at 09:36 AM |
Yes, straight swap,ignore the extra 4 small bolts if the block is not drilled for these, not required.
The newer stretchy bolts feel really horrible when you tighten the heads!
Regards Mark
bitsilly
| posted on 1/2/09 at 10:41 AM |
You might find the 4.6 block is the same size but lighter.
I once had John Eales looking at the best way to increase power to weight for my Westfield and this was the first change we made.
