austin man
| posted on 19/6/09 at 04:41 PM |
pressure regulator
Hi just fitted an adjustable regulator to my Zetec with twin 40's on what is the recommended pressure setting currently got it at 2.5 bar
clairetoo
| posted on 19/6/09 at 04:46 PM |
About 45 PSI - sorry , no idea what that is in `bar`
Its cuz I is blond , innit
Claire xx
Will weld for food......
blakep82
| posted on 19/6/09 at 04:51 PM |
45psi is 3.1 bar.
what regulator is it? what are the regulators adjustment range (i'm thinking about filter king and the like)
________________________
r1_pete
| posted on 19/6/09 at 04:54 PM |
You're on about 37psi for webers, far too much, you need about 3-5 psi...
Steve G
you mean its set at 2.5psi surely?? If so thats spot on for carbs - 2.5 - 3psi
clairetoo
| posted on 19/6/09 at 05:00 PM |
Didnt spot that you are running webbers - I was thinking injection !
As above - 2.5 to 3 psi should do it .
Claire xx
| posted on 19/6/09 at 05:35 PM |
Jeez. 2.5bar for injection. If you put 2.5bar through carbs you'll blow them to smithereens!!
austin man
| posted on 19/6/09 at 08:00 PM |
sorry meant psi so is it 2.5 or 3.00 then
