GrumpyOne
| posted on 12/8/09 at 08:53 AM |
Engines & Gearboxes
Morning Peeps
Can someone confirm that the Jaguar S type gearbox will mate to a V6 Duratec engine?
Also is the ST24 the best Duratec and what is the difference between it and any other V6 Duratec?
Colin
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
Guinness
| posted on 12/8/09 at 09:00 AM |
The Jag version of the V6 Duratec is 3.0 displacement, compared to the 2.5 for the Ford.
The Jag also has VVT, which I don't think the Ford does.
http://www.espritv6.co.uk/
If you get a Jag engine and matching gearbox then I'd imagine that clutches / flywheels / release bearings etc would be simple, rather than
having to be assembled from different parts....
Mike
speedyxjs
| posted on 12/8/09 at 09:41 AM |
The block is the only ford part of that engine. Everything else is pure Jaguar. Not alot of people know that
Mr Whippy
| posted on 12/8/09 at 09:44 AM |
does prompt the question....why?
[Edited on 12/8/09 by Mr Whippy]
speedyxjs
| posted on 12/8/09 at 10:07 AM |
To make it better
Seriously, i would expect it was to stop people thinking it was the same engine as the ford. Dont think it worked
| posted on 12/8/09 at 11:07 AM |
quote: Originally posted by GrumpyOne
Morning Peeps
Colin
Someone has done this and posted some pictures a while back, a search might find it. ISTR that it wasn't a totally simple bolt up job, most of
the holes do line up but some mods were required.
GrumpyOne
| posted on 12/8/09 at 01:16 PM |
Thanks folks
I am back considering my options, engine gearbox wise again. The Cossie BOB engine is giving me more financial grief. It needs a rebuild which I was
going to do myself but even a gasket set for it is £250.
Any suggestions about a good engine, gearbox combination, V6 preferably, that will fit in to a Viento?
bj928
the s type 3.0 rated at 241hp compared to the st24's 170hp, if the block is the only ford part then the bellhousing will bolt up, volvos v8 they
fit in the sc90 is the same bolt patern and so is the v12 aston martin, all based on the duratec v6, its funny how jag say the 3.0 x type engine is
nothing to do with the 3.0 st220, in the dyno shoot outs in the mags, the st220 hits 231hp which is the same as the jag is rated at!!!!!!!!!
