Author: Subject: dip stick
ditchlewis
posted on 23/8/09 at 03:41 PM Reply With Quote
dip stick
Just went out to check the oil level, pulled out the dip stick and the end was missing it must be in the sump
do i now have to take the sump off to fish it out?
advice please please please.
or can it wait till the winter lay up?
ditch
Mark G
posted on 23/8/09 at 03:46 PM Reply With Quote
I'd be removing the sump by now, You don't want that to pick up in your crank or you'll be in a whole world of hurt...
ditchlewis
posted on 23/8/09 at 03:50 PM Reply With Quote
just one thing after another at the moment, had a good blast yesterday, and today its in bits
problem is im busy for the next few weekends as my wife is in hospital for an operation and will take 3 months to recuperate.
thanks for that it's what i thought
ditch
macspeedy
i'm guessing it a pinto you have, i recon the metal strip couldnt get round and into the sump you should beable to fish it out with maybe a magnet or pliers depending on how far its gone in and how good a fit it is in the pipe.
Goodluck!
jonesier1
posted on 23/8/09 at 03:51 PM Reply With Quote
drain the oil,you may be luckyand it comes out,failing that fish for it with an extending magnet through the drain hole.
im in my own little world...its ok though they know me there
ditchlewis
posted on 23/8/09 at 03:55 PM Reply With Quote
yes its a pinto, and the end flat piece of metal from the springie section to the tip is gone. might try the drain down approach first as it realy needs and oil change.
may be lucky then
ditch
posted on 23/8/09 at 03:57 PM Reply With Quote
Good point re removing the oil and hoping it comes out in it... you'll need to remove the oil if you have to take the sump off anyway so worth having a good route round the old oil to see if it's in it....
Mark G
posted on 23/8/09 at 04:05 PM Reply With Quote
just a thought, would you have any joy removing the dipstick tube to see if it is poking out of there.
speedyxjs
posted on 23/8/09 at 05:06 PM Reply With Quote
I think its a contagious illness. I droped a part in my bellhousing yesterday and had to take the engine out to remove it today
jacko
posted on 23/8/09 at 05:52 PM Reply With Quote
Pull the dip stick tube out and you will get it hopefully
ditchlewis
posted on 23/8/09 at 06:20 PM Reply With Quote
no the dipstick tube comes out easily and it is not down there, it was the first thing i thought of.
will try the oil first and than drop the sump.
ditch
owelly
posted on 23/8/09 at 08:32 PM Reply With Quote
If a quick fish around after an oil change doesn't find it, fit a magnetic sump plug and forget about it. I can't think of any situation where it could leave the oil in the bottom of the sump to find its way to do any harm. It's not as if the crank actually touches the oil that's in the sump unless you overfill it!!
http://www.ppcmag.co.uk
dave r
posted on 23/8/09 at 08:34 PM Reply With Quote
i would leave it
quite heavy, wont go thru the strainer, and as above will prob end up on the end of the magnet
