Author: Subject: bike carbs + vac advance
kj
posted on 24/8/09 at 09:54 AM Reply With Quote
I know that if you run bike carbs on say a pinto you have to leave the vac advance disconected or change the dizzy.
I know that some people use a small copper tube with 4 from the carbs into 1 then accross to the dizzy, so would this work as they are cheap, its from micro bore plumbing £3.00.
Think about it, think about it again and then do it.
r1_pete
posted on 24/8/09 at 10:14 AM Reply With Quote
This is how I've done it for magajolt, the large tube provides smoothing for the vac pulses.
Not sure you need that for the distributor, so those connectors should work ok.
mookaloid
posted on 24/8/09 at 10:23 AM Reply With Quote
Pretty sure that it doesn't work for vacuum advance.
you need a proper vacuumless dizzy or megajolt, or just run it without the vacuum connected and advance the timing to suit.
whitestu
posted on 24/8/09 at 11:00 AM Reply With Quote
I'd go with a Megajolt - I had no choice as I run a Zetec, but it is an excellent piece of kit. Being able to connect the laptop and adjust ignition settings accurately on the go is great.
will121
posted on 24/8/09 at 11:42 AM Reply With Quote
im running zx6 carbs on a 1600cvh using the standard vacume advance dizzy connected with 4 hoses from the manifold with no problems
mookaloid
posted on 24/8/09 at 11:51 AM Reply With Quote
How do you know you have no problems? just connecting it all up will not reveal that the vac advance is not working. if you disconnect it from the vac advance and plug the pipe does it make any difference? if not then it wasn't doing anything in the first place.
posted on 24/8/09 at 12:22 PM Reply With Quote
Why would it not work?
Tapping downstream of the butterfly is going to provide a vacuum signal of sorts, since people have used this for MAP sensing with throttle bodies. The real question is not IF this works, but how well this works, since the vacuum signal will be different to the original carb setup.
Maintaining some form of engine load sensing for ignition is greatly beneficial for road use. You can't simply advance the timing to compensate for removing it, since you will also increase advance at high engine loads which vac advance doesn't do.
mookaloid
posted on 24/8/09 at 03:02 PM Reply With Quote
It won't work because there's nothing to maintain the vacuum between pulses on each of the cylinders.
ie when one cylinder is sucking, it won't pull the vac advance because there is an open to air inlet somewhere else and it's easier for air to flow in from one of the other inlets than to pull the vac advance forward. in other words as vacuum is created by one cylinder it is lost by one of the others.
But don't take my word for it, try it with a vacuum gauge and see for yourself.
I'm not saying there won't be any vacuum at all because the 'inertia' of the air will provide a little - enough I believe to read with a MAP sensor for MS but not enough to activate a vacuum advance properly.
I understand that Bogg brothers don't think it works either perhaps a call to them would clear things up?
Mark
jacko
posted on 24/8/09 at 03:36 PM Reply With Quote
Im with Mookiy on this one i had all my vacuum tubes connected together and to the dizzy
Bogg brothers removed them when setting my carbs Mr Bogg set my dizzy to 34% at 3500 rpm till i could get a modified dizzy
Jacko
posted on 24/8/09 at 03:57 PM Reply With Quote
Vac advance is just a part throttle ecomomy device, to enable the engine to run with a weak mixture.
If your carbs aren't designed to work with it don't use it.
