Author: Subject: pinto cam belt tension
kj
posted on 27/8/09 at 07:14 AM Reply With Quote
How did you set you cam belt tension on a pinto, use any gauge or just half inch of movement as some mention?
Also is it ok not to use the spring as it was not on my old engine.
cheers
Think about it, think about it again and then do it.
posted on 27/8/09 at 07:17 AM Reply With Quote
Not a half inch of belt movement --- the standard test is if you can give it a half twist of belt movement on the longest run.
[Edited on 27/8/09 by britishtrident]
adithorp
posted on 27/8/09 at 07:37 AM Reply With Quote
Get hold of the belt with finger and thumb on it edges, on the longest run and trist it. Should get 90' turn (without all the force you can muster).
adrian
http://jpsc.org.uk/forum/
ashg
posted on 27/8/09 at 07:38 AM Reply With Quote
As bt said.
you should be able to do half a twist on the longest part of the belt.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
kj
posted on 27/8/09 at 08:05 AM Reply With Quote
Thanks, sorted.
Surrey Dave
posted on 27/8/09 at 08:32 AM Reply With Quote
90 degrees
Just to clarify , you should be able to turn the belt 1/4 of a twist = 90 degrees
kj
posted on 27/8/09 at 12:26 PM Reply With Quote
Thanks for that just wanted to check
