posted on 18/11/09 at 03:13 PM |
Arrrrgh, ali bellhousing!
Cold out there today mind you... I'm changing the cast iron type 9 bellhousing for an RS2000 ali job, saving 6kg.
New release arm arrived this morning and cracking the bolts that hold the housing to the gearbox I see they are 30mm M12 x 1.5 and too short for the
RS one which has thicker flanges....
So, where can I go get some 35mm M12x1.5 bolts? Local fastener place has minimum order of £10+vat and I only need 4 off not £11.50 worth...
Its never simple is it??
mookaloid
| posted on 18/11/09 at 03:38 PM |
you'll also gain some of the weight back you've just lost with the longer bolts
dhutch
| posted on 18/11/09 at 03:48 PM |
Lol!
Cant help you, unless geting them from my bolt place (min order of 20p being record so far) and posting them snail mail helps.
Daniel
jimgiblett
| posted on 18/11/09 at 03:56 PM |
I would suggest you try an a different motor factors.
Cromwell tools have always helped me out in the past when I wanted a small quantity of non standard bolts.
http://www.cromwell.co.uk
Give them a call.
- Jim
deezee
| posted on 18/11/09 at 04:01 PM |
I could send some out if you want them?
iank
| posted on 18/11/09 at 04:20 PM |
Give them a call.
- Jim
There's a Cromwell branch on the Team Valley. Had a few bits from them, always very helpful in my experience (assuming they stock those bolts)
Anonymous
jambojeef
| posted on 18/11/09 at 07:46 PM |
Its the fasteners place on the the team valley that you want!
Anixter (as was INFAST) - fromt he A1 southbound take the team valley turn - at the roundabout turn right and immediately take the first left.
Anixter are on the corner - dead helpful blokes and they have huge stocks of all kinds of bolts and nuts, washers thread lock - all that kinda stuff.
Must have spent a small fortune there over the years but was worth it.
Geoff
kj
| posted on 19/11/09 at 08:19 AM |
2 place near armstrong industrial estate Washington just up where the old b&q was, realy helpfull the one in the far corner and just normally asks
for a £1 for the coffe machine when i got my 4 prop shaft bolts.
Also a place near Haverton hill industrial estate, can't remember the names sorry.
