Danozeman
| posted on 23/11/09 at 09:11 PM |
cheap place for thread adaptors.
Im after a 1/8 npt female to 1/4 npt male adaptor for my pressure sender.
Wheres the best place? Burtons have one for nearly 8 quid posted?
Dan
flak monkey
| posted on 23/11/09 at 09:14 PM |
Any local engineering supplies place should be able to sort you.
Will only bea few quid for a brass one.
Sera
http://www.motosera.com
| posted on 23/11/09 at 09:15 PM |
Have you checked these...
Vehicle Wiring Products
ETB Instruments
Rally Design
Russbost (on here)
| posted on 23/11/09 at 09:41 PM |
Hydraulics engineers should be able to help for peanuts
stuart_g
| posted on 24/11/09 at 08:27 AM |
Hello Dan,
Go down to PIRTEK on Wherstead Road. I got a couple of adapters there for reasonable money when I couldn't find anything anywhere else. They
have everything on the shelf.
Stu.
Danozeman
| posted on 24/11/09 at 12:47 PM |
Cheers stu ill try pirtek later. i know a bloke down there also. Off the shelf is nice.
Dan
franky
| posted on 24/11/09 at 01:10 PM |
another vote for pirtek..... rally design/merlin and others wanted £20 odd quid for a couple of bits I wanted + post.
Pirkek, £5
| posted on 24/11/09 at 02:55 PM |
As long as the thread length is short it is not uknown to bodge NPT with bsp fittings.
On both the difference in T.P.Iand O.D. isn't massive - 1 tpi and 0.08-0.09 mm in both 1/8" and 1/4" bores
1/8" to 1/4" BSP adaptors are cheap as they are used for airbrush to compressor connections.
[Edited on 25/11/09 by britishtrident]
