stuart_g
| posted on 27/12/09 at 09:27 PM |
clutch cover/pressure plate torque setting
Can anyone tell me what the torque wrench setteing is for the above on a 2.0l Zetec?
I have the manuals on PDF but seem to be missing this section. Can't remember where I got them from so if anyone can point me in the right
directoion that would be good.
Stu.
ashg
| posted on 27/12/09 at 10:27 PM |
just do them up until they are tight at a guess i would say around 60-70nm as its the dowel that does the work.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Mark Allanson
| posted on 27/12/09 at 10:29 PM |
I would go careful, I have just done a Fiat punto and sheared one off at 15ftlbs!
paulf
| posted on 27/12/09 at 10:33 PM |
The dowel actually only locates it in the correct position , the friction between the cover and flywheel faces drive it.
Having said this I never use a torque wrench on clutch covers I just do them up till they feel tight.
Paul.
ashg
| posted on 27/12/09 at 10:56 PM |
i have never done them with a torque wrench either was just trying to put a number on it tbh.
i usually just use a 3/8 ratchet and to them up until they are tight but not going to sheer off.
| posted on 27/12/09 at 11:04 PM |
No way to tight no 8mm dia bolt will take that torque.
A short M8 bolt requires at most 20 ft/lb ---- about 28 newton meters.
No real need to use a torque wrench just a firm pull on a standard length 13mm spanner.
It is however essential to do them up in stages and use a diagonal tightening pattern so as to pull the clutch pressure plate down squarely on to the
flywheel.
Then go round each one again to check for tightness.
| posted on 27/12/09 at 11:09 PM |
Fiat &^$* !
| posted on 28/12/09 at 09:12 AM |
Fiat &^$* !
Don't you mean "case hardened spaghetti"?. I have only ever used a spanner/socket to tighten clutch bolts and I've done a few
in 42 years in the motor trade
