Author: Subject: TD04 Turbo Centre Housing Q?
MakeEverything
posted on 20/1/10 at 06:12 PM Reply With Quote
Doesanyone know how to rotate the centre housing on a TD04 turbo?
I took the clamp off, and removed the large circlip, but couldnt get the exhaust housing to turn.
Also, im not sure its possible anyway, as the inlet housing has a location stud, which will prevent that from turning.
Any ideas? Ive currently got the oil feeds horizontal, which i know is incorrect but have no other option, unless i want to make a 90 degree elbow adapter for the manifold.
Kindest Regards,
Richard.
Volvorsport
posted on 20/1/10 at 06:15 PM Reply With Quote
theres a little peg you need to grind off - you need to seperate them , grind it off , put them back together , rotate .
DONE .
www.dbsmotorsport.co.uk
getting dirty under a bus
MakeEverything
posted on 20/1/10 at 06:52 PM Reply With Quote
ok, ioes the exhaust housing just pul apart? I tried to drive a screwdriver between with the clamp removed, but it didnt seem to want to separate.
Kindest Regards,
Richard.
sebastiaan
posted on 20/1/10 at 06:58 PM Reply With Quote
Chavs to the rescue! ;-)
http://forums.nasioc.com/forums/showthread.php?t=1194742
Looks like the hot side (turbine side) should just pull apart. The cold (compressor) side indeed has a pin / snap ring arrangement. I'm guessing you'll need to clock both?
boggle
can you not turn just the compressor housing?
u2u me for details
MakeEverything
posted on 20/1/10 at 07:01 PM Reply With Quote
No, because of the actuator linkage.
Kindest Regards,
Richard.
boggle
posted on 20/1/10 at 07:13 PM Reply With Quote
sorry, just realised as to what you are trying to acheive....any way you could use the return as the feed???
u2u me for details
MakeEverything
posted on 20/1/10 at 07:17 PM Reply With Quote
Ivegot both connected for now, but they are horizontal, which will lead to heat soak and glazing inside the centre bearing eventually (apparently).
Ive got an accumulator that i could install, but i didnt want to install this or the intercoolers until i was sure the ecu would deal with the additional power.
If it doesnt, then ill go MS on stock equipment as i know that works. From there, i can return to the current project, and play with the fuelling and ignition.
Kindest Regards,
Richard.
