<<  1    2  >>
Author: Subject: diesel engine
andrew
posted on 20/3/10 at 09:54 PM Reply With Quote
diesel engine
anybody know what modern diesel will bolt straight onto type9 box / bellhousing
UncleFista
posted on 20/3/10 at 09:57 PM Reply With Quote
I don't think there's any newish diesel that'll bolt straight up, but anyway, modern diesels have so much torque that surely they'd shred a standard t9 anyway ?
Tony Bond / UncleFista
andrew
posted on 20/3/10 at 10:08 PM Reply With Quote
ok any sugestions
UncleFista
posted on 20/3/10 at 10:13 PM Reply With Quote
There was a bloke in PPC magazine who fitted a VAG TD to his Westfield, I can't remember what gearbox he used though...
I'll have a thumb through my back issues if no-one else remembers
owelly
posted on 20/3/10 at 10:17 PM Reply With Quote
I seem to think he spent a fortune on a bellhousing and kit. Toyota gearbox seems to ring a bell......
http://www.ppcmag.co.uk
PAUL FISHER
posted on 20/3/10 at 11:33 PM Reply With Quote
This might be of some help?
http://westfield-world.com/pics_paulr.html
se7en
posted on 21/3/10 at 12:54 AM Reply With Quote
Does the Ford Transit (Not Connect) use a Type 9 Gearbox?
Simon
posted on 21/3/10 at 12:57 AM Reply With Quote
Alternatively look out for a more modern car that's diesel & rear wheel drive.
Jags and BMW spring to mind - you could possibly use the running gear from a complete 1 series which almost has same size footprint a "7"
Saying that, I was in a friends 307/8? 110HP 1.6HDi last weekend and I was amazed at how thrashable it was, and it still did 45mpg.
Maybe a mid engined alternative might be the way to go.
Simon
[Edited on 21/3/10 by Simon]
mad4x4
posted on 21/3/10 at 01:54 AM Reply With Quote
There front wheel drive IIRCC
Scot's do it better in Kilts.
tonym
posted on 21/3/10 at 08:50 AM Reply With Quote
What about a Sierra diesel?
[Edited on 21/3/10 by tonym]
karlak
posted on 21/3/10 at 09:05 AM Reply With Quote
Would love to have the Diesel out of my everyday Tintop in the Indy. I have the BMW 123d - Basically a 2.0 litre diesel with twin turbos. A smaller one and then a larger one for further up the revs, make it less laggy and then helps with power / torque when both spool up to together.
Amazing really - it does over 200 bhp and still returns 40+ mpg. Have seen mid-50's on a steady run - and a 0-60 in 7 seconds (pre-bluefin ) is not too shabby either.
Have had mine "looked" at by Superchips, and it is now Dyno'd at 252 bhp - with an increase of torque as well. Not sure on the weight of the engine, but this in a Kitcar would be rather quick I think - If you could stop the rears spinning I guess with that torque.
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
StrikerChris
posted on 21/3/10 at 09:24 AM Reply With Quote
not sure about type 9 but pretty sure a primera (about 98 shape) diesel will mate to the 200sx box,but they were only about 130 brake when chipped....
MakeEverything
posted on 21/3/10 at 09:28 AM Reply With Quote
Often thought about a small diesel in a kit car. The fuel economy would be second to none if you get it right, and the torque would be quite addictive i shold think.
Anyone into Tuning Diesels? It wouldnt be right to have a standard diesel, but a "Tweaked" 1.4 or 1.6 would be quite nice if you could get the power out of it.
Kindest Regards,
Richard.
MakeEverything
posted on 21/3/10 at 09:31 AM Reply With Quote
Not the old ones. They were definately RWD.
Kindest Regards,
Richard.
Danozeman
posted on 21/3/10 at 09:40 AM Reply With Quote
Trannies werent type 9. mt75's. The new ones are like mt75's and im sure will mate to the mondeo duratorque engine but would be very heavy.
Vag engines would be the best engines to use. If you get an early AAZ 1.9 you wouldnt need any ecus and stuff then and would still go well. Even the early AFN 110bhp. then all youd need is ecu and throttle pedal and remap to 150. Apparatly with different injector nozzles and a couple of other little bits you can get 200 and in a 7 youd get well over 70mpg.
Im sure an adaptor plate wouldnt be too hard to make up for a decent gearbox.
Dan
Paul TigerB6
posted on 21/3/10 at 09:54 AM Reply With Quote
Really cant see the point of a diesel in a very light weight car. I wouldn't build a se7en for fuel economy - how many miles a year does everyone do in their cars? Too much torque and you'll just end up spinning the wheels all the time.
The guy who built the diesel Westie bought a 3.14 Sierra diff of me 3 years ago or so.
posted on 21/3/10 at 10:26 AM Reply With Quote
I think the "modern" requirement rules that one out!
The 1.8TD in the Sierra was a shocking engine, 67bhp for the early ones, increased to a massive 75bhp later. Coupled with a powerband like the edge of a razor blade and an unhealthy appetite for timing belts it's not really something you'd consider using these days.
Some of the old RWD Transits had a Type 9 coupled to a very agricultural (and stupendously heavy) 2.5 non-turbo diesel.
posted on 21/3/10 at 11:22 AM Reply With Quote
BMW 4 cylinder engine is the best bet --- lots available from Rover 75s. Because it used a simpler turbo the version used in the R75 is more reliable than that in the BMW or Freelander.
131 hp but an easy 155hp via black box.
However while it might pull like a train in a big heavy saloon or 4x4 a disels draw backs are going to show up much more in a light sports car it just won't be free revving enough and like any moder engine it needs lots of electronics to support it.
[Edited on 21/3/10 by britishtrident]
posted on 21/3/10 at 12:07 PM Reply With Quote
Vauxhaul Isuzi diesels will mate up to a 4x4 Isuzu box.
My old 1.5TD Corsa was a rocket ship with some 'mods' to the turbo and pump. Only downside was the amount of black smoke when the pedal was to the metal
smart51
posted on 21/3/10 at 01:03 PM Reply With Quote
The Transit is available as either FWD or RWD.
mangogrooveworkshop
posted on 21/3/10 at 02:20 PM Reply With Quote
Oh Is that so.....better tell ford because the one I just pulled out of the P100 was a Diesel mated to a TYPE NINE........mmmmm
And it on got pulled cause we are going 4x4 v6
beaver34
posted on 21/3/10 at 06:10 PM Reply With Quote
or 4wd
beaver34
early transits were type 9 up to 2000
Simon
posted on 21/3/10 at 08:18 PM Reply With Quote
Torque would be effectively reduced with low enough final drive ratio, resulting in useable gearing, good performance and stunning economy.
I think that's quite a good formula really
Simon
UncleFista
posted on 22/3/10 at 08:34 AM Reply With Quote
Oh Is that so.....
I don't know, which is why I said "I don't "think" and ended the sentence with a question mark.
Still think we need to inform Ford ?
<<  1    2  >>
