Bumble
| posted on 23/3/10 at 11:23 PM |
Idle Valves & Megasquirt Question
Advice please......I am installing Megasquirt to my Zetec which has R6 TB's. MS has ouputs/inputs for Idle valves but as I'm not using
stock equipment I don't have any. Can I do away with the idle valve and control idle in another way through the software? How have others done
it? Any advice would be much appreciated.
Matt
flak monkey
| posted on 24/3/10 at 07:05 AM |
If you are controlling spark as well then you can use cold idle advance to increase the idle speed a little when cold.
Personally I never bothered with idle valves even when running fuel only on the pinto. Just means it runs a little rougher when cold, but only for a
couple of minutes.
Sera
http://www.motosera.com
Bumble
| posted on 24/3/10 at 10:31 AM |
Cheers David......
