Author: Subject: Alloy radiator
motobaleno
posted on 24/3/10 at 11:53 AM Reply With Quote
Alloy radiator
I definitely need much more cooling power in my raw striker due to the new engine.
can you suggest me where (online) I can find thick alloy radiators at good price?
thanks a lot
imp paul
posted on 24/3/10 at 12:03 PM Reply With Quote
ALLOY RACING FABS MAKE 1 OFF JOBYS
boggle
posted on 24/3/10 at 12:15 PM Reply With Quote
pro alloy??
u2u me for details
posted on 24/3/10 at 01:33 PM Reply With Quote
what size radiator?
motobaleno
posted on 24/3/10 at 03:06 PM Reply With Quote
Originally posted by 02GF74
what size radiator?
well I have some flexibility but being a particularly small seven-type car the surface dimensions are quite limited (something around 50x40 cm), for this reason I need a thick one: at least 10 cm...
blakep82
posted on 24/3/10 at 03:41 PM Reply With Quote
you can get a brand new VW polo ali radiator from northern radiators for about £30. popular choice on here. don't know what you've already got right enough.
________________________
posted on 24/3/10 at 05:44 PM Reply With Quote
Usual advice re rads is
"do you really need a bigger rad or do you need to improve airflow through the capious open nosecone of a 7?"
Sevens have a ridiclous amount of air flowing into the nosecone. Only problem is most of it goes round the rad. Channel it through the rad and job's a good 'un unless you're running crazy Bhp....
turbodisplay
posted on 24/3/10 at 05:55 PM Reply With Quote
And just as importantly get the airflow out.
Darren
motobaleno
posted on 2/4/10 at 08:33 AM Reply With Quote
any suggestions how to better channel the flow into the nosecone?
iank
posted on 2/4/10 at 09:10 AM Reply With Quote
The air goes into the nosecone just fine, but if there is a gap around the radiator most of it will just go round (path of least resistance).
As said you also need to let it out again after it's done it's job.
Anonymous
