<<  1    2  >>
Author: Subject: Positive displacement supercharging basics
NS Dev
posted on 1/4/10 at 08:33 AM Reply With Quote
Righty-ho!
I'm looking into putting a positive displacement supercharger onto a vauxhall XE16v engine.
I am looking to run around 20psi boost, where I can without mechanical limitations.....
That's where I'm a little unsure of how best to do things!
if I gear the blower to give me 20psi of inlet pressure, I'll then get that throughout the rev range, which is going to cause me problems at low revs I would assume!
How do I deal with this, can I use a wastegate and operate this to give me the boost I need (I can drive the wastegate via the dta ecu)
cd.thomson
posted on 1/4/10 at 08:35 AM Reply With Quote
Okay so....
could you do that to my dax next
Craig
turbodisplay
posted on 1/4/10 at 08:39 AM Reply With Quote
A bypass valve would work, it would need to be quite big, maybee 30 - 50mm as it will need to flow a fair volume to reduce the boost. I would say a throttle body fron a small car will work well.
Darren
NS Dev
posted on 1/4/10 at 08:45 AM Reply With Quote
would a 60mm wastegate do it?
Don't really want to get into actuators for a butterfly!
NS Dev
Originally posted by cd.thomson
Okay so....
Its not for the locost! I's even madder than that!
cd.thomson
posted on 1/4/10 at 08:46 AM Reply With Quote
Okay so....
Keep us updated!
Craig
Miks15
posted on 1/4/10 at 08:57 AM Reply With Quote
surely it wont be running max boost all through the rev range?
It wont be spinning as fast 1k RPM as it will at 7k?
blakep82
posted on 1/4/10 at 09:16 AM Reply With Quote
unless the pulleys on the engine and supercharger are the same diameter, wouldn't the boost rise in a sort of exponential graph way?
ie, if the supercharger pulley is half the diameter of the crank pulley, for example, if the engine spins at 1k, the charger goes at 2k,
engine--------charger
2k----------------4k
3k----------------6k
4k----------------8k
5k----------------10k
6k----------------12k
7k----------------14k
i think thats how it would work anyway, so the boost increases the faster the engine goes? so 20psi is your maximum boost, but only goes to that at full speed?
flak monkey would know more about it i think. he's supercharging a duratec isn't he?
________________________
posted on 1/4/10 at 09:40 AM Reply With Quote
No, with a positive displacement supercharger the engines air consumption is proportional to the amount of air the supercharger is compressing, so you get fixed boost (in theory). In practice the non-constant VE of the engine and inefficiencies in the supercharger means it will vary a bit.
[Edited on 1/4/10 by MikeRJ]
alistairolsen
posted on 1/4/10 at 09:41 AM Reply With Quote
the belt will effectively give a gear ratio, so charger speeds will be as you posted blake rising at a greater rate then revs.
You will only make peak boost at max revs which is why you get away with keeping a high CR.
EDIT, positive displacement, Doh! Mike is right, if the engine can consume say 3l of air for each cycle (150% VE jammed into 2l) and the charger compresses 1.5l per rev and runs twice as fast, ignoring odd losses this relationship will stay the same throughout the rev range.....
I dont see why an external wastegate couldnt be made to work with the appropriate springing but I dont know how well they seal when closed (potential boost leak)
What charger are you using? 20psi is a fair old whack!
IMO, work out your desired power, select a charger which will flow that amount of air below its peak safe rpm, gear it to run at max safe rpm at the rev limit and leave boost control entirely until you see if you have a problem with knock or excessive ignition retard when mapping.
Edit again: as above for the power you want but as you noted and I misunderstood, run a wastgate or a throttle butterfly and a wastegate actuator from an internally gated turbo to control the boost.
[Edited on 1/4/10 by alistairolsen]
My Build Thread
NS Dev
posted on 1/4/10 at 09:47 AM Reply With Quote
With regard to both the above posts.... yes the charger will be spinning faster at higher revs, but of course so will the engine!
The charger will 'pump' a fixed volume of air for each rotation. the exact volume is changed by altering the pulley ratio, but the volume of air for each revolution of the engine will be fixed, so the boost pressure will be fixed at all revs. Not like a turbocharger.
Eg. 1 rev of engine rotates charger 2 revs (if 2:1 pulley ratio). this will be the case at 1000 revs or 8000 revs.
posted on 1/4/10 at 09:49 AM Reply With Quote
Originally posted by alistairolsen
the belt will effectively give a gear ratio, so it wont be exponential, but will be as you posted blake rising at a greater rate then revs.
The supercharger will be moving a volume of air proportional to the speed of the engine, the engine is consuming air proportional to it's speed. e.g. imagine the engine consuming 500cc of air per revolution and the supercharger moving 1 litre of air, this ratio remains fixed.
The only simple way I can think of reducing boost is some kind of bypass valve. A young lab in a recent copy of PPC magazine had used an external turbo wastegate to do exactly this on a supercharged K series in his Imp. It was only running 4psi though I think.
turbodisplay
posted on 1/4/10 at 10:08 AM Reply With Quote
You will need a low pressure spring, as this is your lower boost limit. I.e. a wastegate set to 8 psi will not go lower that 8 psi as the gate will close(and boost will go back up).
You may need to lap the valve to get a good seal, although leakage will be small in any case.
Darren
NS Dev
posted on 1/4/10 at 10:54 AM Reply With Quote
ahhh cheers Mike now I remember that article (though 4 psi sounds a bit limp to me!! )
Looks like wastegate and a nice boost map in the ECU will be the way to go, now I need a nice cheap but reliable bleed valve........isn't there one on newer audis and vw's that everybody uses, could be bosch??
NS Dev
posted on 1/4/10 at 10:56 AM Reply With Quote
Darren
mmmm also a good point. should be able to find something soft enough to do the job I would think
posted on 1/4/10 at 11:41 AM Reply With Quote
It was a completely standard 1.8 VVC engine which has a pretty high CR to start with (10.5:1), I think he was just playing safe until he could beef the engine up a bit.
Liam
posted on 1/4/10 at 12:17 PM Reply With Quote
I dont really know owt, but isn't it not quite that simple? I mean at idle/low speeds there'll be leakage round the rotors etc. I.e. you dont really get max boost at idle/low speeds anyway. I guess it would build to max pretty quick though, so with 20psi peak I can see why you might want to reduce boost at low speeds!
Sort of sounds like you'd rather have the characteristics of a centrifugal blower or turbo, so why not use that in the first place? Again I dont know owt, or know owt about your application either - I'm sure there's a reason you want the positive displacement blower or you wouldn't be asking.
So that probably doesn't really help then
Liam
flibble
posted on 1/4/10 at 02:05 PM Reply With Quote
With an eaton sc on my old mx6 the boost I wanted was only 7psi, it was probably around 4psi at 900rpm (idle) with 7psi arriving by about 1000rpm and was solid all the way to 7k, the later eatons had a recirc valve integrated into them so no need for external ways to get rid of unwanted pressure, mine was an earlier one so I had to plumb my own in, basically a normal recirc valve although I seem to remember slightly different as it had to be open while cruising as well as decelerating, all in all they are very easy to set up (must be if I managed ).
You can see the acuator for the new chargers on the bottom right of the pic, same arrangement as turbo wastegates:
Edit: From Eatons site:
Do the Superchargers provide boost at all times?
No. Under cruising conditions, the compressed air from the supercharger is bypassed, and is recirculated in the supercharger, improving fuel efficiency. Under acceleration, the bypass is closed, and the “boosted” air is sent into the engine to provide increased response and power
[Edited on 1-4-10 by flibble]
flak monkey
posted on 1/4/10 at 07:34 PM Reply With Quote
Eaton/rootes blowers are massively inefficient at high boost levels (over 10psi) and you are far, far better with a centrifugal one.
The reason for this is the amount of 'mashing' you get from the rotors which heats the inlet charge much, much more than a centrifugal one.
You can run constant boost and limit it with an external wastegate, which can have electronic boost control controlling the wastegate to dump any boost over a certain level. Then its all electronic and doesnt rely on any vac controls or anything.
I would seriously think about running a C38 rotrex or similar though for that sort of boost or you'll end up with more detontation issues than anything else I would suggest.
Have a read of Supercharged! by Corky Bell, its the only book you needs. Coveres both types of supercharger and gives their merits and weakenesses and a whole host of other useful info.
ETA yes you should run a bypass valve, or preferably a BOV which will dump the boost at idle and light cruise which keeps close to NA MPG figures on the road.
[Edited on 1/4/10 by flak monkey]
Sera
http://www.motosera.com
flibble
posted on 1/4/10 at 11:37 PM Reply With Quote
Agreed with the inefficiency and heat at high boost, also with corkys book being excellent although i'd have to disagree with a BOV over bypass valve, I tried running with it ventining to atmosphere and the noise is horrific, even at idle
Edit: Having a brain fart about the high boost inefficiency now, wouldn't a big charger with a relatively low rpm be ok? If it's deigned to supply say a 4.0L engine at 10psi wouldn't it be just as happy pumping the same volume into a 2.0L but resulting in higher pressure?
NS Dev
posted on 2/4/10 at 08:30 AM Reply With Quote
................exackerly!
The "plan" and I use that term VERY loosely, is to use an eaton M90 supercharger on a 2 ltr 16v vauxhall engine, with 8.5:1 compression ratio.
I DON'T want a centrifugal blower, we already have a 500hp turbo 16v vauxhall and it would be no good at all for what I need it for!
It won't be used on the road so economy etc is of no issue whatsoever.
The idea is to use a big eaton blower, spun nice and slowly (around 1:1 with the engine) so it stays reasonably efficient (ok pushing things at 20psi but not ridiculous)
As I say, I know nothing about supercharging though, and I already realise that one of the issues I overlooked is that I planned to throttle the inlet on the blower, doing it the "old fashioned way" which should resolve the idle issue anyway.
On those "internal bypass" eaton blowers, do they throttle the inlets or outlets in a typical OEM setup?
I think on the jags (where I plan to liberate the blower from! ) they throttle the inlet don't they?
I now don't know what the issues will be when the throttle is cracked open from idle, I assume due to high boost/low rpm/low piston speed, there will be a big det. risk, so lots of ignition retard and excess fuel, but I have no idea!
Everything I have read/heard talks about high boost only at high rpm and piston speeds..............
Pretty obviously (though will be blue sky thinking I'm sure! ) I'm trying to "simulate" a big engine's torque delivery with a smallish and lightish unit.
I know from the vauxhall turbo that the std pistons and rods are quite happy at 425hp and 380nm of torque, but its what happens at lower rpm when the boost is far higher than it would be in a similar turbo setup............
[Edited on 2/4/10 by NS Dev]
flibble
posted on 2/4/10 at 09:20 AM Reply With Quote
As far as I'm aware, theres no "throttling" as such, its either on or off, it just instantly opens a passageway from the outlet back to the inlet so the air just recirculates until it slams shut again when you put your foot down
[Edited on 2-4-10 by flibble]
NS Dev
posted on 2/4/10 at 10:43 AM Reply With Quote
no I mean the actual throttle, as in operated by the driver's foot.
flibble
posted on 2/4/10 at 12:16 PM Reply With Quote
Ahhh, doh! Not sure on that count then I had throttle on the outlet, I'd guess they normally throttle the inlet but that's based on bugger all an guesswork
flak monkey
posted on 2/4/10 at 12:39 PM Reply With Quote
If you are running without a bypass you will need to put the throttle on the intake side of the supercharger.
If you run with a valve you can throttle on the outlet side if you wish.
The main problem with having lots of boost at low RPM is controlling knock/detonation as it much harder to overcome at low RPM than at high.
Certainly sounds like an interesting project anyway!
Sera
<<  1    2  >>
