Author: Subject: Bestek Ignition
Barksavon
posted on 2/4/10 at 07:53 AM Reply With Quote
Bestek Ignition
Has anyone got any comments on Bestek Distributors and electronic ignition systems, particularly on Pinto's with twin side draughts. Ta
robocog
posted on 2/4/10 at 11:18 AM Reply With Quote
Megajolt and EDIS with coil pack would be the way I would do it (in fact I did)
It has plenty of scope and features and is not that expensive or difficult to setup
...unless the Bestek unit you have found is really really cheap and your not bothered about being able to map the iginition to suit your engine, set rev limits shift lights etc
Regards
Rob
john_p_b
posted on 2/4/10 at 11:27 AM Reply With Quote
had no problems with mine, fitted when i had twin 40's but i have sinse removed them and the ignition system is still just fine. fit and forget really.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
Garyd
posted on 2/4/10 at 11:35 AM Reply With Quote
Got this ignition on my x-flow and no probs since I fitted it 2 yrs ago.
Barksavon
posted on 2/4/10 at 12:07 PM Reply With Quote
Rob Ive seen a lot mentioned about Megajolt but dont know much about it. Can you enlighten me any or point me in the direction of a supplier and whether there are different types / modules etc, does it replace the standard electronic ignition module and coil etc, i am aware that i would need to modify a dizzy to drive the oil pump....
blakep82
posted on 2/4/10 at 12:15 PM Reply With Quote
have a read through this
http://www.autosportlabs.net/Megajolt_Lite_Jr.
takes a little setting up, but works really well. it's what i'm using. set up your maps on a PC while the engines running etc. set rev limits, shift lights, advance can be controlled by either manifold pressure or throttle position. they come as DIY kits normally that you build yourself, but there are people (on here) who will build and test them for you. i forget how much mine was, but was around the £100 mark (for the megajolt alone) a few years back. you'll also need a trigger wheel & sensor, and fords edis 4 system from a 90s escort
________________________
bmseven
posted on 2/4/10 at 02:54 PM Reply With Quote
Ditto with 40's
BMW 7 Resource
Bures Pit anyone?
