Daddylonglegs
| posted on 14/4/10 at 11:19 AM |
Clutch Pedal Travel
How much travel should I expect on the clutch pedal and operating arm? Sorted out my previous issue of a high pedal, but not sure if the pedal travels
far enough. The adjuster seems to be doing it's thing, and the cable outer is tight up against the stops at each end.
It's a type-9 BTW
JB
Lars
| posted on 14/4/10 at 12:19 PM |
Just test it
switch on the engine, while depressing the clutch
if the car tries to jump forward through the garage wall you want more travel
Lars
| posted on 14/4/10 at 12:21 PM |
I vcan measure mine tonight, but I guess it will depend on pedal and clutch
Daddylonglegs
| posted on 14/4/10 at 12:57 PM |
quote: Originally posted by Lars
Just test it
Unforutnately I'm not quite at the 'go' stage yet otherwise I would)
speedyxjs
| posted on 14/4/10 at 12:59 PM |
Put in highest gear. Foot on clutch and turn the output shaft by hand. Slowly bring clutch up and when you can no longer turn the shaft, that is your
biting point.
Daddylonglegs
| posted on 14/4/10 at 02:56 PM |
Cheers Speedy Never thought of doing that
Can do that from the driver's armchair too
[Edited on 14/4/10 by Daddylonglegs]
speedyxjs
| posted on 14/4/10 at 03:25 PM |
You have an armchair in a locost?!?!?!?
And i tought my car was luxury having a driver foot rest
